Like Tree1Likes
  • 1 Post By Trekka
  #1
Old 05-21-2012
Trekka's Avatar
Seasoned Salt
Trekka is on a distinguished road
Good (cheap) source for stainless pipe
I am preparing to mount a Rutland wind generator. I found part of what I need on eBay, the basic pipe that holds the gen, the base mount, and attachment points for supporting rods.
But I still need the supports, ie the pipe/rods that attach to the main pipe and angle out to attachments on the hull and deck. These pipes should be around 3/4 to 1" diameter and 6-8ft long. At West the prices are outrageous and not long enough. Most items can be found elsewhere, so does anyone have suggestions?
Locations in Annapolis/Baltimore especially appreciated.
jaydensmith likes this.
  #2
Old 05-21-2012
micheck is on a distinguished road
Re: Good (cheap) source for stainless pipe
Many on Google --- try Speedy Metals Online Industrial Metal Supply
  #3
Old 05-21-2012
Captainmeme's Avatar
Captainmeme is on a distinguished road
Speedy list only 304/304L stainless tubing, no 316.
Will 304 hold up in a saltwater environment?
Prices look good.
  #4
Old 05-21-2012
misfits is on a distinguished road
Not sure how cheap $$ you're looking for, what about sailrite?
Also check with pipe distributors/steel suppliers in your area.
Home | The Blue Book Building and Construction Network
Blue Book is a nationwide network for vendors/subs, pretty much anything to do with the construction industry.
I'm not happy unless I'm complaining about something.
I'm having a very good day!
  #5
Old 05-21-2012
jrd22's Avatar
Courtney the Dancer
304 is acceptable for marine, and it's actually stronger than 316.
John
SV Laurie Anne
1988 Brewer 40 Pilothouse
  #6
Old 05-21-2012
Ninefingers is on a distinguished road
Hmm, the prices look pretty reasonable when I went to West Marine site. http://www.westmarine.com/webapp/wcs...splayErrorView
  #7
Old 05-21-2012
dfreer is on a distinguished road
Check with Dons Marine Salvage (info@dmsyard.com) They have a large selection of ss tubing stock at good prices and will ship world-wide. They are located in Florida.
You may post attachments
You may edit your posts
Good (cheap) source for foam panels? peterchech Gear & Maintenance 3 05-01-2012 04:03 PM
Finishing stainless pipe for wind generator ereiss Gear & Maintenance 17 11-20-2010 07:13 PM
Stainless Hot Pipe? downeast450 Gear & Maintenance 0 02-19-2010 12:55 PM
Source for Stainless Rail Fittings gilsurf Gear & Maintenance 2 06-02-2007 08:20 AM
Good source of U-Bolts spinnaker Gear & Maintenance 5 05-24-2007 12:01 PM
SEO by vBSEO 3.6.1
