Wire to Rope Halyards - Page 2 - SailNet Community
 1Likes
post #11 of 17 Old 05-21-2012
Re: Wire to Rope Halyards
Originally Posted by tommays View Post
On the Cal 29 they are all external and don't touch or rub or cut anything
On the Cal 29 to make the external thing work the sheaves are GIANT with a price to match
On my J24 it started out life with wire/rope in 1981 and at some point as the sheaves needed no mod it went to all high tech rope
Other than the fishhooks on the wire its about the same on the J24 as the loads are low
There is a bunch of stuff on the market with jackets now that are stupid slippery and do NOT work so it can be a costly experiment if you do NOT play with a sample of the cordage your going to use
As the boats get bigger between the lenth of line and the high loads there is a much bigger payback
Tommy, there's a pretty large knowledge base out there of what works and works well. Line casing/covers can be dealt with pretty easily to rough them up a bit. Honestly, I haven't been on a boat big or small with wire halyards for years. Even the old IOR war horses around here have gotten ride of theirs long ago, and if anything loads up a rig, it's an IOR boat. I wouldn't advise anyone to rush out and change if they're happy, but if it's time to change a wire that's worn or meat hooked, it's a no brainer to update. There should also be reasonably priced hardware for the top of your mast when the time comes. Chances are it'll be much smaller and lighter than what you're using now.
puddinlegs is offline
post #12 of 17 Old 05-21-2012
Junior member, rest old
msmith10's Avatar
I'm with Tommays. I've got wire to rope in good shape. No kinks or meathooks. My old C&C 30 mast is a telephone pole, so a few ounces of weight aloft is not gonna make me win or lose a race. When I have to change out, I'll go to all rope, but there's no sense spending a couple hundred bucks until I have to.
Mark Smith
1977 C&C 30 Mk 1 hailing from Port Clinton, Ohio
msmith10 is offline
post #13 of 17 Old 05-22-2012
Wish I never found SN!
SimonV's Avatar
If you have even one meathook, its time to replace. The main location for them is the point at which it sits on the sheave when under load. I Have wire to rope on my boats main halyard and have had no problems but regularly check it and the splice. One thought about wire and rope, Which is going to last better in the tropical sun.
Simon
Ericson 39B.
I love my boat
S/V GOODONYA
Brisbane
present location Gold Coast
DELIVERY SKIPPER
Drinking Rum before 10am makes you a Pirate NOT an alcoholic
SimonV is offline
post #14 of 17 Old 05-22-2012
tommays's Avatar
While all the standing rigging and clevis pins are brand new as IMHP it you cant lock down the age its to OLD to trust
After 30+ years of J24s with water pouring into the bilge from all the openings for the internal halyards ,you could get 10 to 15 gallons on a week like this with 3" of rain
The old school deck steped Cal 29 mast with ZERO leaks is kind of nice and short of welding on a new masthead you are stuck with the sizes they picked as they are needed to prevent chafe and 6" stock to DIY new ones is bucks
1970 Cal 29 Sea Fever
1981 J24 Tangent 2930
Tommays
Northport NY
tommays is offline
post #15 of 17 Old 05-22-2012
With modern lines there is no, absolutely no reason to continue to use wire. Skip over all the polyester lines and go strait to dyneema. It is cheaper by breaking strength than sta-set, stronger than steel wire by size, and much less stretchy. It's one real limitation is it is very slippery, so you need to add a cover right at the point where the jammer, or cleat is to prevent it from slipping off.
This should take a good rigger about 5 minutes to add, or someone who has never done it before about 20 minutes the first time.
Stumble is offline
post #16 of 17 Old 05-23-2012
SchockT's Avatar
I remember back in the day when all the IOR war horses had wire halyards. As the foredeck guy it was standard procedure to check all the halyards for meathooks, and when I found them I would whip out my trusty leatherman and file them off!
My boat is of that vintage, and I have wire genoa and main halyards. They are still in great shape so I have no reason to replace them. Thats the thing about wire, is that it can last forever! If I got serious about racing my boat I would probably replace them with a modern rope just to reduce weight aloft. Wire halyards are far heavier than rope. The down side of modern ropes is that they are more vulnerable to UV and weathering and chaffe. Alot of race boats that have expensive high tech halyards will attach tracer lines to the halyards and hoist them to the masthead to protect the rope from the elements. This is often because the outer protective sheath has been removed to further reduce weight.
SchockT is offline
post #17 of 17 Old 05-23-2012
Schock,
The people who are doing that still just got in the habit from old arimid (kevlar) lines and are still doing it from habit, not necessity. Dyneema is almost completely UV stable, and running chase lines is no longer necessary.
In commercial fields it is seeing a longer working life than steel cable, and the same base material when used for standing rigging has a recommended replacement life of 8 years (as compared to 8 years for wire).
Stumble is offline
halyards rope vs wire CowbaySailor Gear & Maintenance 13 07-07-2011 10:22 AM
Changing from wire-rope to all rope hoppy Pearson 5 04-18-2011 04:42 PM
Replacing wire halyards with rope DRM Gear & Maintenance 2 03-21-2006 04:49 PM
Wire-to-Rope Halyards Dan Dickison Gear and Maintenance Articles 0 05-06-2002 09:00 PM
Wire-Rope Halyards Tom Wood Gear and Maintenance Articles 0 08-14-2001 09:00 PM
