Old 05-22-2012
scratchee's Avatar
scratchee is on a distinguished road
Gotchas during re-launch after 4 wks?
Hey Folks,
I'm two months into boat ownership and my Cal 2-27 with Atomic 4 has been on the hard for a month for seasonal hull maintenance.
I didn't prep anything when they hauled her. Is there anything I should look out for when she's relaunched this Friday (just shy of four weeks after hauling?) I'm thinking about engine cooling, stuffing box, stuff like that? She has fresh water cooling, if that makes a difference.
  #2
Old 05-22-2012
FSMike's Avatar
FSMike is on a distinguished road
Re: Gotchas during re-launch after 4 wks?
Check the fluid levels (oil, coolant, batteries). Make sure she's pumping water when you start the engine. How long has it been since the stuffing box was repacked? Might want to do that as preventive maintenance. Bottom paint?
Sail Fast Live Slow
40' Norman Cross trimaran
  #3
Old 05-22-2012
scratchee's Avatar
Thanks Mike. I don't know how long since it was repacked, but I did tighten the stuffing box with the PO, and he seemed confident that it had some life left in it (I'm sure he knows, and he probably told me, but I don't remember.) I was mainly thinking about the flax drying out or something, since I understand it works by being wet.
I'll check the fluids too. There are no puddles under the boat so they should be good!
I just painted the bottom today. I only used one coat because she got 2 coats last year, which is supposed to last two years.
  #4
Old 05-23-2012
JimsCAL's Avatar
JimsCAL is on a distinguished road
Check the shaft bearing for wear. If you can move the shaft back and forth more than 1/16 inch, its time for a new one. Also check the rudder bearings for wear in the same manner.
  #5
Old 05-23-2012
Captainmeme's Avatar
Captainmeme is on a distinguished road
Zincs?
You may post attachments
You may edit your posts
Launch Day! mceveritt General Discussion (sailing related) 4 06-18-2010 06:14 AM
Launch sailortjk1 General Discussion (sailing related) 11 04-22-2008 10:50 AM
Launch Day Birdface Boat Review and Purchase Forum 3 08-07-2006 12:11 PM
Launch day NewsReader Sabre 0 07-28-2006 03:15 PM
SEO by vBSEO 3.6.1
