ST40 Wind problem - SailNet Community
post #1 of 6 Old 05-23-2012 Thread Starter
ST40 Wind problem
Hi All,
Since I have had my mast back up this year I am getting a 0.0 readout all the time on my ST40 wind instrument, even when the anemometer is spinning away up there. Accoring to the manual if the wiring isn't connected the display will read all dashes which its not doing. I am going to try to calibrate it per the manual tomorrow. Does anyone have any other ideas what to do?
Thanks
76 C&C 38
jetdrvr393 is online now
post #2 of 6 Old 05-23-2012
Once known as Hartley18
Classic30's Avatar
Dock
Re: ST40 Wind problem
Is this just a stand-alone instrument or is it on a Seatalk network?
Classic30 is offline
post #3 of 6 Old 05-24-2012 Thread Starter
It is stand alone. We have the ST40 speed/depth but as far as I can see they are not hooked together in any way.
76 C&C 38
post #4 of 6 Old 05-24-2012
No more curry buffets
Ritchard's Avatar
I had a problem with my ST40 wind where the wiring got pinched on raising the mast, and I think it was registering 0.0, rather than dashes. Seems to me you're going to have to look over the wiring bottom (first) to top.
And further to this topic, I thought long and hard about ST60 vs ST40 wind. Having spent so much money on refitting my old boat over the winter, I was very hesitant to blow 3 times as much money on the ST60. When Defender had ST40 on sale in spring and Westmarine (local, Canada) matched it, the decision was made.
Turns out it works great for my purposes. I really like having a wind speed reading, and it works fine for setting the autopilot to wind angle. The ST60 likely works better for the latter, but the ST40 is just fine.
OP, you really should seatalk your two instruments together so you can get true wind. It only takes a cable.
Bashing about on Lake Ontario and Beyond
"Ariel" '79 Endeavour 32
Ritchard is offline
post #5 of 6 Old 05-24-2012
JimsCAL's Avatar
Most likely the cable running from the readout to the sensor on the mast. Check connectors first. Since you just put your mast in, the ones at the base of the mast are most suspect.
JimsCAL is offline
post #6 of 6 Old 05-26-2012 Thread Starter
Well, checking the connections is probably out. I don't want to have to pull the mast just for that.
Anyone know of anything else I could try? (Even if its a hail mary)...
76 C&C 38
Raymarine ST40 Wind docbob5707 Gear & Maintenance 8 08-09-2012 10:13 PM
ST40 wind - for powerboats? Ritchard Electronics 2 11-03-2011 02:25 PM
ST40 Wind system zz4gta Gear & Maintenance 2 11-16-2009 06:31 PM
mast transducer for ST40 wind xken Gear & Maintenance 2 03-03-2008 09:35 AM
Ramarine ST40 Wind mikehoyt General Discussion (sailing related) 0 03-24-2004 06:29 AM
