Wood deck maintenance? - SailNet Community
post #1 of 2 Old 05-25-2012 Thread Starter
utchuckd's Avatar
Assuming they're solid and in good condition, just how maintenance intensive are those wooden decks on the Cheoy Lee's? There's one or two in my area I'd like to go see, but don't know anything about them.
utchuckd is offline
post #2 of 2 Old 05-25-2012
Siamese's Avatar
Re: Wood deck maintenance?
I don't like ANY wood maintenance on a boat, but aside from maintaining the decks, your primary concern might be for determining whether that which is directly under the wood is sound. It's essentially a teak deck screwed to a fiberglass deck, so there are hundreds of holes to be considered.
If the deck has some age on it, then there's the possibility of water having entered the screw holes and causing problems with the deck core. Much caution is advised.
Siamese is offline
Wood maintenance on the top side dgasmd Gear & Maintenance 6 04-23-2011 05:04 PM
Deck maintenance imiloa Gear & Maintenance 1 08-05-2010 08:07 PM
Wood Boat Maintenance starlightventure Gear & Maintenance 11 12-28-2009 04:37 PM
cable on keel and wood in deck Flatfendershop MacGregor 4 11-20-2008 11:54 PM
Deck Maintenance grinfax Gear & Maintenance 9 08-05-2008 08:11 PM
