Is my hull in serious danger? - SailNet Community
 1Likes
post #1 of 11 Old 05-26-2012 Thread Starter
maine89's Avatar
Exclamation [SOLVED] Is my hull in serious danger?
I had some very helpful people in the sailnet chat room helping me out today and eventually the topic of my hull came up and I showed these pictures:
https://s3.amazonaws.com/Boat/IMG_0565.JPG
https://s3.amazonaws.com/Boat/IMG_0570.JPG
close up https://s3.amazonaws.com/Boat/IMG_0571.JPG
close up https://s3.amazonaws.com/Boat/IMG_0572.JPG
close up https://s3.amazonaws.com/Boat/IMG_0573.JPG
https://s3.amazonaws.com/Boat/IMG_0584.JPG
https://s3.amazonaws.com/Boat/IMG_0583.JPG
Is this somewhat normal and nothing to lose sleep over (it's almost 3am) and a modest griding and re-glassing will fix it, or do I have a really bad potential issue here?
1975 27' O'Day "Ice Breaker"
Heart is in Maine
Boat is in Rhode Island
maine89 is offline
post #2 of 11 Old 05-26-2012
bigdogandy's Avatar
Dock
Re: Is my hull in serious danger?
Can you see the area inside the boat where these cracks occur? From the pics it looks like the boat may have had some serious damage at some time in the past and the repair is starting to fail. I'd check it out from both sides to make sure you know how deep the cracks are....glassing from inside the hull may be needed.
I'm sure you'll get a lot of feedback from the group on this one.....Good luck and send updates as you do the investigation, OK?
wdwright1967 likes this.
Andy
Key Largo
S/V Everlasting Moon
1981 Endeavour 32
Be joyful though you have considered all the facts.
- Wendell Berry
bigdogandy is offline
post #3 of 11 Old 05-26-2012
I'd have a surveyor/professional take a look at this. At least then you'll know what the score. Get some sleep, it's only a boat.
I'm not happy unless I'm complaining about something.
I'm having a very good day!
misfits is offline
post #4 of 11 Old 05-26-2012
Looks like it may have taken a heavy hit, maybe near the back portion? If the oval patch was not from removing a saildrive it certainly looks like it may have been holed. or pounded on a rock. As mentioned above, pictures from the inside might confirm that? Doesn't look good to me. Do you have any history on it? A quick survey would probably be worth it. Let us know what tou find.
Paul T
dabnis is offline
post #5 of 11 Old 05-26-2012
tommays's Avatar
The pictures are not taken in a way that allows the size and location of the issue to be understood BUT it looks to more than a minor problem
1970 Cal 29 Sea Fever
1981 J24 Tangent 2930
Tommays
Northport NY
tommays is offline
post #6 of 11 Old 05-26-2012
souljour2000's Avatar
Looks to me that it's more than gelcoat stress here...and I agree with above posts that it looks like it took a hard it or got dropped by a forklifter or fell of it's cradle.....
souljour2000 is offline
post #7 of 11 Old 05-26-2012
I can't really tell where these pictures are located which limits the usefulness of my opinion, but I would say given what I can tell you have a very serious problem until proven otherwise.
Some of those pictures look to be leaking rust, which could typically mean oly a few things. If they are pictures of the rudder skeg then you have a crack that runs into the rudder post. If they are pictures of the keel, then the crack runs all the way to the keel bolts, which have started to corrode away badly enough that rust is leaking out.
Either way it could be a major repair, dropping the rudder/keel would just be the start.
The circle looks like a bad through hull fitting patch, but I didn't get a good sence of scale. If that's all it is it isn't so bad. Just grind out the bad, patch with new, bottom paint and go sailing.
The transom damage looked like it is non-structual really. But still grind out the bad, patch and repaint.
Stumble is offline
post #8 of 11 Old 05-26-2012
Forgot this: You may want to carefully check where the bulkhead(s) are tabbed to the hull. Any sign of cracking or de-lamination may be a sign it has taken a heavy impact(s).
Paul T
dabnis is offline
post #9 of 11 Old 05-26-2012 Thread Starter
maine89's Avatar
Yes you guys are right. I take lots of pictures because the boat is about 100 miles from me so I need to reference things by picture a lot. Sadly I didn't use any objects for scale and even my "zoomed out" shots were actually pretty zoomed in. When I looked at the boat in person again (wondering how I could have missed the severity) the cracks were not that bad.
Regardless, we grinded the cracks out down and reglassed them. I dremeled out the transome and other gouges in the hull and filled with a filler and will gel coat tomorrow.
You are exactly right. The previous owner did a very shoddy patch job on two through hulls. It was basically a plastic plug and some sort of caulking. The good news is the fiberglass hull is over an inch thick where the center through hull was, that is reassuring.
I think I'm going to be OK!
Heart is in Maine
maine89 is offline
post #10 of 11 Old 05-26-2012
Dont want to scare you but i am betting you have serious ingress of salt water to your keel bolts. My advise is to do one of two things. drop the keel and have a look then go from there or have the keel bolts xrayed. you could have a very serious problem. do not sail that boat with your family till you fix it right. You can loose your keel at sea and topple over if you know what I mean. do not, I repeat do not just patch the crack, your life could be in jeapordy.
Freedom007 is offline
Sailboat Rigging Danger eherlihy Gear & Maintenance 8 11-18-2009 03:40 PM
Danger Will Robinson - Danger! Spiritman Electrical Systems 26 04-21-2009 10:41 PM
Danger timebandit General Discussion (sailing related) 25 09-17-2008 10:10 AM
