Inflatable personal PFDs material or fabric - SailNet Community
post #1 of 2 Old 05-26-2012 Thread Starter
Hi
Does anyone knows what type of fabric or material are used for light weight personal inflatable pfds or life jackets ?
Basically I am looking for light weight , strong fabric to build a custom made jacket and I have seen several names such as Pylon,rubber coated nylon etc been mentioned but not sure what are the best.
Please email me if you know where I could get this material
email: noorkota@hotmail.com
n00b is offline
post #2 of 2 Old 05-27-2012
Re: Inflatable personal PFDs material or fabric
n00b, typically a pfd is made from a welded polyurethane bladder, with a nylon shell over it. The art of welding your own urethane bladde should be beyond most home craftsmen. I suppose you could make a lightweight one out of calendared nylon, which has a light urethane coating calendared into one side of it to make it waterproof, but those materials ALWAYS break down, the only question is whether it will take five years, or ten.
The only way I'd try to make a pfd would be using conventional closed-cell foam as a conventional floatation jacket. Inflateable? No way. Not unless you're going to buy the urethane and the right tools for plastic welding. (Including welding in the inflator and overpressure relief.)
hellosailor is offline
Inflatable PFDs -- Manual or Automatic? Capetinho General Discussion (sailing related) 28 10-02-2011 09:30 AM
Inflatable PFDs jarcher Gear & Maintenance 48 08-27-2009 03:31 PM
