epoxy barrier coat sun exposure how long is too long? - Page 2 - SailNet Community
post #11 of 19 Old 05-29-2012
Re: epoxy barrier coat sun exposure how long is too long?
A tarp skirt around the bottom of a boat can be a problem for an extended period. You should not attach them to the stands and, depending on whether you can stake them in the ground, they may not withstand a good storm.
I would not worry about a blister drying out properly if left exposed for a year.
My plan A would be to grind whatever you need to fix and have her soda blasted next year. They will tent her in to do that job and can probably do so earlier than you could stand getting under there for a couple of weeks. They only need a couple of days.
If this is all you have to do, I would actually sail her this season and do this all next year, including professional stripping.
Jeanneau 54DS
Minnewaska is offline
post #12 of 19 Old 05-31-2012 Thread Starter
johnnyandjebus's Avatar
Hello All
An update
I have started to sand into the hull, using a small belt sander. The ridgid mentioned in this thread. So far so good, it is small enough that I have enough control to not make a mess of things and it's dust collection is working well. At this point it is more exploratory work than a full hull strip. None of the areas are blisters, just areas that look like the epoxy has been compromised. For the most part things look dry but I am finding some pitting into the hull;
Can anyone tell me is this the result of a flawed layup at build time or a result of osmosis/hydrolysis?
After sanding I flush with water, let dry then wipe with acetone, a day later the pits are dry.
John
"The more I know about people, the better I like my dog."
-- Mark Twain
"If you canít explain it to a six year old, you donít understand it yourself.Ē
--Albert Einstein
johnnyandjebus is offline
post #13 of 19 Old 05-31-2012
Without seeing it they could be anything from a bad fairing job, to slight water intrusion points, old repairs poorly done, ect...
The really question is if they are wet after cleanup then you may have some moisture in the hull. Since you are planning to keep the boat out of the water for a while anyway I wouldn't worry about it. In the spring come back and fair the hull with thickened epoxy, then reapply a barrier coat, then bottom paint and off you go.
Stumble is offline
post #14 of 19 Old 06-01-2012
I'm pretty sure those are just air bubbles left when the glass mat was laid up against the gelcoat. It is nearly impossible to get all the air out during layup. Note that non-woven glass mat is ussually the first layer against the gel coat so that the woven cloth pattern doesn't print through the gelcoat. When moisture gets into the glass mat it follows the glass fibers and the fiber changes color in a very obvious way.
Gary H. Lucas
GaryHLucas is offline
post #15 of 19 Old 06-02-2012
Interesting about your barrier coat. When my boat was new I had the yard put a coal tar epoxy barrier coat on the hull prior to launch. That was 25 years ago with the boat spending almost it's entire life in the water with a haul out every several years for new bottom paint. I wish I could tell you that I have no blisters, but that is not true. Now I find out that the barrier coat is good for only about 10 years so my question is why apply it in the first place if it needs to be removed in 10 years. (I don't think you would just apply another barrier coat over the old coat.) Seems like removing a barrier coat would be harder than removing just the gel, but I expect to find out soon. Trying to get a good price on a peel and then letting it dry our for a year. Good Luck
lancelot9898 is offline
post #16 of 19 Old 06-02-2012
Oh...One other detail is that one yard that I spoke with puts up to 14 layers of epoxy barrier coats on the hull bottom after a peel.
post #17 of 19 Old 06-02-2012
fiberglass1's Avatar
"14 layers of epoxy barrier coat?" Sounds like either BS (of the let me impress you variety) or someone needs to do a little more research. The companies that make barrier coats spend a fair amount of time testing their products and they probably have a pretty good idea of how many coats are necessary. I've never seen 14 coats recommended by anybody.
fiberglass1 is offline
post #18 of 19 Old 06-02-2012
Most manufacturers recommendations require a certain thickness regardless of the umber of coats. Interlux recommends 10mills, though how you get it is up to you. But it shouldn't take anywhere near 14 coats to get there, 4-5 is pretty typical.
I guess if you were doing an ultra high level racing boat, and applied very, very thin sprayed on coats it might take that many... But I have never heard of anyone doing that.
Stumble is offline
post #19 of 19 Old 06-02-2012
I also have never heard of so many coats needing to be applied. When the boat was previously done there was just one coat applied via sprayer. Not sure of the thickness. Still think it's interesting that only a 10 year life is projected for that original coal tar epoxy barrier coat. Maybe more thickness was needed. As I get into doing this project more will be learned.
Epoxy Barrier coat stevemorrell Gear & Maintenance 7 01-15-2016 02:32 PM
Epoxy Barrier Coat over Gel Coat? lizardheadone Gear & Maintenance 4 01-14-2016 10:08 PM
2012 Oceanis 45 Epoxy barrier coat kellysails Beneteau 3 05-10-2012 06:19 PM
tar epoxy barrier coat on fiberglass erpwyeth Gear & Maintenance 2 06-13-2010 08:30 PM
EPOXY BARRIER COAT DILEMMA, help ..... Freesail99 Gear & Maintenance 5 06-07-2010 08:14 AM
