Rigging - Page 3 - SailNet Community
 3Likes
post #21 of 21 Old 06-16-2012
Senior Moment Member
SloopJonB's Avatar
Re: Rigging
Go with colour coded lines - the cost differential in $$ on a small boat is not significant on a small boat, even if the %% difference is large.
You can estimate your needs with the following rules of thumb.
Halyards - The length of the forestay plus the height of the mast plus the distance from the mast to the cockpit plus a few feet
Jib/Gennie sheets - 1 1/4 - 1 1/2 times the length of the boat.
Spinnaker sheets - twice the length of the boat.
Mainsheet - the distance between block shackles with the boom at 90 degrees X the number of falls plus a few feet.
SloopJonB is online now
Tags
maintenance , rigging
Rod Rigging Rustyf General Discussion (sailing related) 15 01-31-2012 10:00 PM
Junk/Sampan rigging vs. Cat rigging ClaireFAISE General Discussion (sailing related) 10 09-21-2010 08:59 PM
Does your rigging have this? superdave Gear & Maintenance 17 05-26-2007 11:23 AM
New Rigging eduardodias Gear & Maintenance 5 08-23-2006 09:20 AM
rigging dankel Gear & Maintenance 2 06-20-2005 01:18 PM
