Voltage tester idea - Page 2 - SailNet Community
 1Likes
post #11 of 27 Old 11-13-2012
Re: Voltage tester idea
slowbut, the question is, just how accurate is that little meter?
hellosailor is offline
post #12 of 27 Old 11-13-2012
Senior Slacker
SlowButSteady's Avatar
I had the same question when I bought it, so I compared it to my Tenma digital multimeter (which was fairly high-end when I bought it 20 years ago). Essentially, the little plug-in meter was spot on (to within the precision of its readout, anyway).
Never forget them. Do something to prevent it from happening again.
Charlotte Bacon, Daniel Barden, Rachel Davino, Olivia Josephine Gay, Ana M. Marquez-Greene, Dylan Hockley, Dawn Hochsprung, Madeleine F. Hsu, Catherine V. Hubbard, Chase Kowalski, Jesse Lewis, James Mattioli , Grace McDonnell, Anne Marie Murphy, Emilie Parker, Jack Pinto, Noah Pozner, Caroline Previdi, Jessica Rekos, Avielle Richman, Lauren Rousseau, Mary Sherlach, Victoria Soto, Benjamin Wheeler, Allison N. Wyatt
SlowButSteady is offline
post #13 of 27 Old 11-14-2012
Barquito
Barquito's Avatar
I use one that plugs into a cigarette lighter socket. Like this:
Looks like that battery is about 50% SOC (depending on voltage drop to battery)?
Valiant 32
Barquito is offline
post #14 of 27 Old 11-14-2012
Senior Slacker
That's just an image I found on the net of the same model as the one I have.
post #15 of 27 Old 11-15-2012
Stu Jackson's Avatar
Could you not deliberately oversize the wires from your bank to your voltmeter?
Stu Jackson, Catalina 34, 1986, M25 engine, Rocna 10 (22#), Maple Bay, BC, Canada
Stu Jackson is offline
post #16 of 27 Old 11-15-2012
Senior Slacker
Actually, I'm in the process of upgrading some of the wiring on the boat right now. The little plug-in meter is being replaced with a hard-wired one (and an "(ON)-OFF-(ON)" toggle switch, so I don't have to switch the master switch back and forth to test both banks). However, I am going to run heavier gauge wire to all the plugs to avoid voltage drops.
post #17 of 27 Old 11-15-2012
Maine Sail's Avatar
The volt meter should ideally be run directly to each battery with its own wire and should not pull off the "panel". This keeps the monitoring wires free of loads thus no voltage drop other than the mA to power the LCD of the meter which means squat to the wire. Your meter won't have the resolution to even see the load of the volt gauge in terms of volt drop..
______
-Maine Sail / CS-36T
Maine Sail is offline
post #18 of 27 Old 11-15-2012
Senior Slacker
That's what I'm installing, except that it's an analog meter.
post #19 of 27 Old 11-15-2012
Stu-
"Could you not deliberately oversize the wires from your bank to your voltmeter? "
Voltmeters always draw SO little power in the sense leads, that you'd really have to try hard to find a wire guage small enough to have any voltage loss on that run.
Even one of the "self powered" two-lead LED types, what is the total consumption? Maybe 100mA?
post #20 of 27 Old 11-15-2012
asdf38's Avatar
Probably pretty accurate. Multimeter hardware isn't expensive and DC voltage is the easiest thing to measure. At work we have all fluke meters but at home and the boat I have 3 of these:
http://dx.com/p/auto-range-digital-multimeter-9636
As for the OP's question what Mainsail and Hello said are exactly right. You can't have voltage drop without current. If there's no current between where you're measuring and the battery it will be 100.00% accurate.
To put it in perspective a regular self-powered multimeter has 10+ Megaohms equivalent input impedance - you could measure your DC voltage a hundred miles away with 16 gauge wire and it would be less than 0.1% off due to voltage drop from the meter.
asdf38 is offline
Moisture tester woes davidpm Gear & Maintenance 15 09-12-2010 09:51 PM
Battery Load Tester seattleclimber Electrical Systems 10 11-09-2009 11:48 PM
Hull integrety Tester davidpm Gear & Maintenance 1 12-09-2008 08:12 PM
Looking for audio circuit tester PhilipMarsh General Discussion (sailing related) 2 05-22-2002 09:56 AM
Low Voltage DC Air Conditioning Tom Wood Gear and Maintenance Articles 0 09-29-2000 08:00 PM
