Voltage tester idea - SailNet Community
 1Likes
post #1 of 27 Old 05-28-2012 Thread Starter
davidpm's Avatar
Voltage tester idea
I do not have a wired in voltage meter. The Bene 32s5 has idiot lights on the panel for 11,12,13. Not sure how they are useful at all.
It is a bit of a hassle to get to the batteries.
If I would get a cigarette lighter plug and put a couple of alligator clips on it can I simply plug that into the 12 volt plug then to my meter and use the main battery switches to select the battery I want to check?
Will this work?
davidpm is offline
post #2 of 27 Old 05-28-2012
Re: Voltage tester idea
Battery volt meters are nearly worthless as they do not really tell you much. A battery can read 12.5 V and still have almost no capacity. On liquid electrolyte batteries, I think the best way (maybe only way) is a hydrometer to measure spec grav of the stuff.
Frogwatch is offline
post #3 of 27 Old 05-28-2012
Once known as Hartley18
Classic30's Avatar
Dock
Originally Posted by davidpm View Post
Will this work?
Yes it will..but it won't tell you a lot more about the state of charge (SOC) of your battery than the current idiot(ic) lights do.
Time to fork out for a Battery Monitor - either the Victron or the Xantrex will tell you all you need to know, and much more.
Classic30 is offline
post #4 of 27 Old 05-29-2012
asdf38's Avatar
Voltage tester idea
It will work fine. One thing to remember is where the lighter plug is wired. Any load between the battery and the point where the lighter is wired will cause a small around of voltage drop. This is probably at your panel so turning off loads will give you the best measurement.
Also be careful with the exposed wires. You could easily blow a fuse if they touch. If you want to use this often you might wire a series resistor of 100 to 1k. Then it's no big deal if you short the alligator clips.
asdf38 is offline
post #5 of 27 Old 05-29-2012
David, it will work but I'd suggest two other options.
One being a plug-in voltmeter, the display is on the "lighter" plug itself. Digital or LEd bars, both are available.
The other is to buy a pair of "pygmy" hippo clips from Rat Shack, crimp a run of duplex wire and a fuse onto them, and bring out the leads direct from the battey for a "cleaner" reading.
In either case the voltage will be a good reference for you, relative to the charge state of your batteries, but subject to all the usual ways to misread the information. Starting with the accuracy of the meter, no matter what kind you have, and whether it has been calibrated. I finally stopped wondering which meter was wrong and by how much, and built a little "10.00" voltager reference supply. That's all it puts out, and exactly what it puts out, accurate to a few thousandths of a volt. So when I need to know if my meter is on drugs, or just a little slow, I check to see if it says "10.00" when it is connected to the calibration source.
As the Wicked Queen said, "Meter meter on the wall, who's the foulest of them all?"
davidpm likes this.
hellosailor is offline
post #6 of 27 Old 11-08-2012
Yes it will work but you will not get accurate reading from your meter because it is not directly connected into the batteries. You should remove the batteries for good readings because when you do this method you will get a small voltage drop from the batteries....
jorn85 is offline
post #7 of 27 Old 11-13-2012 Thread Starter
davidpm's Avatar
How does one do that?. Seems like a good idea.
davidpm is offline
post #8 of 27 Old 11-13-2012
You chase down a handful of electronic parts that Radio Shack won't have, and then most important of all, buy some breathe mints because an (mini in this case) Altoids tin is the most effective way to put a case on anything. Small project boxes are incredibly expensive. Of course the Altoids box doesn't LOOK very commercial, and I suppose the TSA would be closing down airports if they even saw it (good lord, a metal case with wires and a battery!) but if I wanted to keep it under a sawbuck, that was how it had to happen.
Or maybe I should have splurged on the fancy case and taken it to West Marine? (VBG)
post #9 of 27 Old 11-13-2012
Tim R.'s Avatar
I higher recommend the Victron 602.
Tim R.
Our Carina is for sale
1997 Caliber 40LRC
Tim R. is offline
post #10 of 27 Old 11-13-2012
Senior Slacker
SlowButSteady's Avatar
I use one that plugs into a cigarette lighter socket. Like this:
The only problem is that the socket is a bit of a distance from my boat's batteries, so there is a bit of a voltage drop (even more so if I use the socket on the forward bulkhead).
Never forget them. Do something to prevent it from happening again.
Charlotte Bacon, Daniel Barden, Rachel Davino, Olivia Josephine Gay, Ana M. Marquez-Greene, Dylan Hockley, Dawn Hochsprung, Madeleine F. Hsu, Catherine V. Hubbard, Chase Kowalski, Jesse Lewis, James Mattioli , Grace McDonnell, Anne Marie Murphy, Emilie Parker, Jack Pinto, Noah Pozner, Caroline Previdi, Jessica Rekos, Avielle Richman, Lauren Rousseau, Mary Sherlach, Victoria Soto, Benjamin Wheeler, Allison N. Wyatt
SlowButSteady is offline
Moisture tester woes davidpm Gear & Maintenance 15 09-12-2010 09:51 PM
Battery Load Tester seattleclimber Electrical Systems 10 11-09-2009 11:48 PM
Hull integrety Tester davidpm Gear & Maintenance 1 12-09-2008 08:12 PM
Looking for audio circuit tester PhilipMarsh General Discussion (sailing related) 2 05-22-2002 09:56 AM
Low Voltage DC Air Conditioning Tom Wood Gear and Maintenance Articles 0 09-29-2000 08:00 PM
