Adding an adjustable backstay without adding a split backstay - Page 2 - SailNet Community
post #11 of 12 Old 05-29-2012
tap
Re: Adding an adjustable backstay without adding a split backstay
You're going to have to cut and shorten your backstay to make room for the purchase, so while you're at it you might want to consider changing to a dyneema backstay. Look into what it costs to get a new fitting for your wire and compare that to length of appropriate strength amsteel. You might be able to get a new lightweight backstay for close to the same price.
With a dyneema backstay, for the top block of the cascade system, you could use one of these. Antal-Low-Friction-Rings You splice the backstay around the outside of the ring, then run the purchase through the center. The rings have a high load for $$ vs a block. And if it broke, the purchase and backstay are still connected whereas a block breaking would disconnect the two.
If you want 12:1 or more, consider using multiple cascades instead of a bulky 6:1 with two triple blocks. Something like this, which is a 16:1 system. The two cascade blocks could be rings.
tap is offline
post #12 of 12 Old 05-29-2012
sigmasailor's Avatar
Maybe the system on the Sigma 33 OOD: Bekijk bootfoto's - YachtWorld.com is useful. Because of the lever and the 4 fold block and tackle there was some good purchase. Photo 11.
sigmasailor is offline
Adding adjustable backstay sandycohen Gear & Maintenance 7 05-15-2011 08:52 AM
Adjustable backstay of a masthead rig? OhioTom General Discussion (sailing related) 10 07-01-2009 08:56 AM
Adjustable Backstay? lrak Gear & Maintenance 5 08-16-2008 12:53 PM
Adjustable Backstay B49 kawabonga Beneteau 0 02-06-2008 10:04 PM
Adjustable backstay help, please? bobmcgov Gear & Maintenance 10 01-25-2008 01:41 PM
