Tohatsu 6HP 4 stroke propeller comparison - SailNet Community
post #1 of 9 Old 05-29-2012 Thread Starter
New 6HP 4 stroke Tohatsu outboard at 6,000' elevation nets about 4.8 HP from what I have read. Boat is a 12' long 5' wide Jon boat, kind of shaped like a brick,
total loaded weight of about 700 pounds. Stock prop was 7.8 " diameter
X 8" pitch. To lower trolling speed changed to a 7.9" diameter X 6" pitch which worked well. Top speed with the 8" pitch was 10.1 mph. Top speed with the 6"
pitch was 10.5 mph. Sounded like it was reving a little more with the 6" pitch but did not get into the rev limiter. Although our boat does get up on a plane it appears the 6" pitch does provide more thrust as the top speed increased. If put on a displacement hull it appears the 6" pitch prop would provide more thrust, I think.
Page 50 shows the propeller options:
http://www.tohatsu.com/tech_info/own...03-11059-6.pdf
Paul T
dabnis is offline
post #2 of 9 Old 06-03-2012
Misanthrope
TohatsuGuru's Avatar
Re: Tohatsu 6HP 4 stroke propeller comparison
You need to put in the high altitude jets
Elvin
Solution One Maritime
TohatsuGuru is offline
post #3 of 9 Old 06-03-2012 Thread Starter
Fairly often we go to a lake that is close to sea level and I have some concerns about it running too lean? It runs perfectly at 6,000 feet with no indication of it stumbling or being too rich. The little bit of gain in top end power isn't worth having to change the jets back and forth. However, that being said if you think it is harmful for it to be a little on the rich side at 6,000 feet I would be interested to know more. Thanks for your input.
Paul T
dabnis is offline
post #4 of 9 Old 06-03-2012
Misanthrope
The engine is effectively drowning in fuel at 6000. It will not hurt anything, but the plugs are going to foul out and you have a 10% power loss.
Elvin
post #5 of 9 Old 06-04-2012 Thread Starter
OK, so noted. Typical day for us is 2 to 3 hours of trolling then a flat out 10 to 15 minute run back to the ramp. We have about 6 trips on it so far with no problems. I will check the plug and if it looks like it came out of a 2 stroke I will get the high altitude jets. As long as it is not washing the oil out of the cylinder, it should be OK? It runs perfectly as is. Many thanks for the feedback.
Paul T
dabnis is offline
post #6 of 9 Old 06-04-2012
Misanthrope
Not a huge deal at 6K. At 7500 it's an issue that would need to taken care of
Elvin
post #7 of 9 Old 06-05-2012 Thread Starter
Lake Tahoe, at about 6,200 feet is the highest we go to, so far, so good but will keep an eye on the plug. Thanks again for your input. Great motor, by the way.
Paul T
dabnis is offline
post #8 of 9 Old 06-07-2012
Misanthrope
On behalf of the ex-Honda engineer who designed it 14 years ago...Thank you
Elvin
post #9 of 9 Old 06-08-2012 Thread Starter
I have had Honda cars, motorcycles, snow blowers, generators, and outboard motors for years. In my opinion they are perfect. I was going to buy the Honda 5HP but for the same weight I got the Tohatsu 6HP instead. The Tohatsu works perfectly also.
Paul T
dabnis is offline
Nissan / Tohatsu 6h 4 stroke audeojude Outboard 261 09-08-2015 05:59 PM
changing from 4 stroke to 2 stroke newhaul Gear & Maintenance 9 10-02-2010 03:42 AM
Tohatsu 3.5 or 4 HP? galernikus General Discussion (sailing related) 15 10-26-2008 10:08 PM
2 stroke vrs 4 stroke outboards dsbentley Gear & Maintenance 11 07-10-2006 11:27 PM
Tohatsu 6hp 4-stroke? safarisurf Gear & Maintenance 3 07-06-2006 11:43 AM
