Old 01-03-2004
tm3 tm3 is offline
tm3 is on a distinguished road
Rear Seal Replacement
Ahoy,
This past sailing season I noticed more oil then I consider okay in my oil drip pan. My ex engine mechanic said it was a rear seal leak which is common and I need not worry about it. I used two quarts of oil over the season.
Another mechanic also said after checking that he has seen much worse on the majority of the engines he has worked on.
I''m wondering if I''m going overboard by wanting to have the rear seal replaced.
Boat is a 84 sail with the original 50hp Perkins with approx. 3000 engine hrs.
Have intentions of heading south next season via the ICW where the engine will be used more then usual.
Thanks ahead of time for all comments.
Old 01-06-2004
socalsail is on a distinguished road
Is it leaking from the transmission or the engine. If its the transmission and its a Velet Drive its not too hard to do.
Old 01-07-2004
tm3 tm3 is offline
It''s the transmission.
What is "velet drive"?
Deisel Rear Main Seal pma_foyl Gear & Maintenance 1 06-22-2004 07:24 AM
Packless Shaft Seal (PSS) bkdehuff General Discussion (sailing related) 4 04-20-2004 05:41 PM
Hunter 30 "replacement skylights" Jazzlstner Gear & Maintenance 0 04-11-2003 09:47 AM
Real Seal stuffing box maintenance MarkClayton Gear & Maintenance 3 07-08-2002 05:52 AM
Replacement Teak and Holly Sole (C&C 37) thomsonjd Gear & Maintenance 2 11-29-2001 05:17 PM
