Old 05-30-2012
leogallant's Avatar
leogallant is on a distinguished road
Freeing up stuck seacocks
Is there any kind of penetrating oil that will work to free up seacocks that haven't been cycled in so long that they are stuck on the open position?
Leo
Journey to Charleston on Ubiquitous
Steve's Ubiquitous Blog
  #2
Old 05-30-2012
DrB DrB is offline
DrB will become famous soon enough
Re: Freeing up stuck seacocks
Is the boat in or out of the water? In the water, you have limited options, especially since the seacock is in the open position.
If out, repost and I can give you a few ideas.
DrB
If you liked my advice/response, give me some rep points. If you didn't......well what do you expect, it was free.
  #3
Old 05-30-2012
PorFin's Avatar
Señor Member
PorFin is on a distinguished road
Leo,
What type of seacocks? Bronze tapered plugs? Stainless/bronze ball valves?
  #4
Old 05-30-2012
canadianseamonkey's Avatar
Caribbean Surveyor
canadianseamonkey is on a distinguished road
My bronze seacock for my engine was seized open. When the boat was hauled I removed the seacock, put it in a vice, heated up the outer housing with a torch in order for it to expand and I got it to finally move. I keep those suckers greased all the time now.
  #5
Old 05-30-2012
sea_hunter's Avatar
Senior Cruiser
sea_hunter is on a distinguished road
Ball type cannot be heated or the teflon seal will be destroyed. We had a number that were ceased one being a ball type which I decided to replace on a haulout that turned out to be the right decision. Heats not a good thing with most t-hulls but rapping them with a small peen sometimes loosens them. Tapered ones can be loosened without a complete disassemble from inside the boat but may need a rebuild. The safe course is to haulout.
  #6
Old 05-30-2012
asdf38's Avatar
asdf38 is on a distinguished road
I have a stuck one and I'm currently out of the water. Not sure of the type but it's the larger kind for the holding tank outlet. Definitely looking for ideas. I had previously heard about boiled water.
1979 Contessa 26
Boston, Ma
  #7
Old 05-30-2012
newportermike is on a distinguished road
Recently had experience with the boat I bought. It had been on the hard for two years and all the seacocks were seized. I had to dismantle them and regrease. These were the cone type bronze and it was a bit of a pain all right but now they are fine.
  #8
Old 05-30-2012
leogallant's Avatar
I believe they are all Bronze, tapered. Yes, am inclined to wait until its on the hard. Thanks, everyone!
Leo
  #9
Old 05-30-2012
travlineasy's Avatar
Morgan 33 O.I. Perryville
travlineasy will become famous soon enough
My boat has 7 seacocks, and 5 of the 7 were froze when I got the boat. Soaking them with WD-40 for about an hour freed every one of them and they work just fine now. Some were tapered brass, while others were ball type. WD-40 sure cures a lot of sailboat ailments.
Cheers,
Gary
  #10
Old 05-30-2012
leogallant's Avatar
Cheers,
Gary
Will definitely try that!
Leo
You may post attachments
You may edit your posts
Seacocks SloopJonB Gear & Maintenance 1 01-01-2012 09:16 PM
Freeing pulley sheaves VallelyJ Gear & Maintenance 1 03-28-2010 03:28 PM
Freeing stuck valves, in water? WanderingStar Gear & Maintenance 22 12-27-2009 10:34 AM
Seacocks - Again MeCaptainBinky Gear & Maintenance 13 10-19-2008 10:10 PM
stuck seacocks wumhenry Gear & Maintenance 22 07-14-2006 10:46 AM
SEO by vBSEO 3.6.1
