Aluminium mast damage/repair - Page 2 - SailNet Community
 4Likes
post #11 of 17 Old 06-03-2012
Over Hill Sailing Club
smurphny's Avatar
Re: Aluminium mast damage/repair
What I have seen done is to get maybe a 3' section of the exact mast extrusion (unless it's a real oddball, they are somewhat standard and available), slice it along its length so that it can be squeezed to slide up inside the existing mast. Smear with epoxy, slide one inside the other and s.s. rivet them together. This can even be done to join two broken pieces of a mast. The outside can then be faired out to look better.
smurphny is offline
post #12 of 17 Old 06-03-2012
Smurphey,
This is the basic process of sleaving, except that you use a extrusion piece made specifically to match the mast you have. These pieces are available from most manufacturers even for mast profiles that are no longer made (they keep the dies for this purpose).
Cutting a section of a mast down the middle though has two problems. 1) it probably won't fit, since most masts have a different inside profile than outside, and 2) significantly weakens the sleeve.
Remember particularly since this repair is at the bottom, it has to handle all the compression loads and torque loads generated in the entire mast. Weakened sections here are a major problem.
Stumble is offline
post #13 of 17 Old 06-03-2012
smurphny's Avatar
Certainly even better to have a piece that will fit exactly. The older simple oval mast shapes work pretty well shrinking them by slitting on one end of the egg shape but having a complete section would be much better. In a keel stepped mast like this one, there can be a lot of movement and stress at the deck intersection so whatever the OP does, it needs to be more than cosmetic. Am wondering if a good welder could not build up the hacked areas and grind down smooth or just fish plate it. Would have to be someone experienced at welding aluminum masts.
smurphny is offline
post #14 of 17 Old 06-04-2012 Thread Starter
Thanks you all for your input. We had a guy from an aluminium fabrication shop take a look at it today. He said he could weld it up no problem but wouldn't put any guarantee on the integrity of the mast, even though he thought that would be a sufficient repair.
For the sleeve fix, that seems beyond what I would want to try as a DIY project which means I would have to ship the mast to a yard that could do the work.
For reason mentioned in early posts I am concerned with the location of the scratches/gouges so am not sure I could sleep easy wondering if the weld really is enough of a fix. Decisions decisions......
lanya is offline
post #15 of 17 Old 06-04-2012
smurphny's Avatar
It could not hurt to have a sleeve right at that point where it gets wedged. The only thing I'd worry about with welding on plates is what the heat and differential in flex caused by dissimilar materials might do to the long-term strength, especially around a circumference. Can you get an exact fit interior sleeve? If so, that would seem like the way to go.
smurphny is offline
post #16 of 17 Old 06-04-2012
If you really can't afford a new mast - make a compression post from the base of the mast step to the underside of the deck with enough fiberglass and metal to act as a mast step/collar and deck step the mast. Might have to add a few deck stringers to support the weight.
sailor50 is offline
post #17 of 17 Old 06-05-2012
Lanya,
Call the extrusion maker and talk to them. Sleaves can be welded in place, but can also be riveted in place. Particularly where as here, there is some remaining strength in the extrusion you have.
Stumble is offline
Installing aluminium mast steps on steel mast asivesind Gear & Maintenance 10 01-29-2012 10:05 AM
Repair Corroded Aluminium water tank Searanger SailNet FAQ 6 07-07-2010 05:16 AM
How would you repair this hull damage? cosmoking Gear & Maintenance 13 05-07-2009 02:12 PM
Best way to repair this fiberglass damage? FishFinder Gear & Maintenance 11 04-20-2009 03:49 PM
Damage repair for winter storage, how? deckhanddave General Discussion (sailing related) 13 11-20-2006 07:47 AM
