Aluminium mast damage/repair - SailNet Community
 4Likes
post #1 of 17 Old 06-02-2012 Thread Starter
Looking for some input and advise on damage done to a keel stepped aluminum mast. The boat was damaged in the tsunami last year and in the hast of getting her rigging removed and the boat hauled out of the water the owner did a number on the mast by using a sawzall to cut the mast free from the seal where the mast passed through the cabin top. There are gouges in the mast from the saw blade all they way around the mast. Most are fairly superficial but a few of the gouges cut about half way through the aluminum.
I don't know much about aluminum and it's integrity. I am wondering what kind of repair could/should be done. How concerned should I be about structural issue of the mast as is? Unfortunately the yard where it is currently sitting does not have much knowledge in this area. Any recommendation on repair facilities in the Pacific Northwest would also be appreciated?
Attached are the pictures of the gouging.
https://picasaweb.google.com/1167699...9366/June22012
Thanks you for any advise or input.
lanya is offline
post #2 of 17 Old 06-02-2012
Tartan 27' owner
CalebD's Avatar
Re: Aluminium mast damage/repair
I'm not a metallurgist.
Most of the damage I see in your pics looks superficial.
The mast has to stand up to compression loads.
I'm not sure if you should have the newly exposed aluminum anodized but likely a good idea. I'd also guess that with some marine epoxy and cloth you could build up a collar over the damaged area.
What kind of boat is it?
Welcome to sailnut.
Everybody has one:
CalebD is offline
post #3 of 17 Old 06-02-2012
Dog Ship's Avatar
Don't cover it up with epoxy, that will allow moisture to do even more damage over time. You should have the mast sleeved for a best result.
Wow, a sawsall, people never cease to amaze me with the things they do.
Dog Ship is offline
post #4 of 17 Old 06-02-2012
Sleeve it or replace it are the only two options. Any gouges that go deep into the metal at a minimum will create major stress risers, and will cause the mast to fail when it's stressed.
Stumble is offline
post #5 of 17 Old 06-02-2012
Do nothing radical, Here's what I'd do. Wrap it in wax paper tightly. Split a large piece of PVC pipe to go around it over the wax paper with maybe 3/8" clearance. At bottom of PVC, cover the gap with duct tape. Fill the annular space with epoxy and allow to set.
Carefully use a hacksaw to slit the epoxy inside where the PVC is slit. The wax paper is your release layer. You now have a mold of your mast in two halves. Use huge SS hose clamps to hold it around your mast. You can remove it whenever you like for inspection but I'd seal the top around the mast with silicone seal.
Frogwatch is offline
post #6 of 17 Old 06-03-2012
While your at it pray to fairys to keep your mast up. About as effective.
Stumble is offline
post #7 of 17 Old 06-03-2012
PNW... Call CSR in Seattle.
puddinlegs is offline
post #8 of 17 Old 06-03-2012
Over Hill Sailing Club
smurphny's Avatar
I'd probably get section of mast and sleeve it. That's a bad place to screw around with a cosmetic fix.
smurphny is offline
post #9 of 17 Old 06-03-2012 Thread Starter
CableB - The boat is a Tashiba 31. Beautiful boat in great shape other then the hack job on the mast.
Puddinlegs - Thanks for the reference, I'll look em up.
lanya is offline
post #10 of 17 Old 06-03-2012
Sabreman's Avatar
Stumble is right. This suggestion will have no benefit because:
1. The epoxy "sleeve" has no strength because there is no reinforcing material like roving or carbon fibre.
2. The "sleeve" is split which is an inherent weak point.
I highly recommend consulting a professional rigger and refrain from DIY in this case. Most DIY solutions will look good but have no structural benefit.
Sabre 38 "Victoria"
Sabreman is offline
Installing aluminium mast steps on steel mast asivesind Gear & Maintenance 10 01-29-2012 10:05 AM
Repair Corroded Aluminium water tank Searanger SailNet FAQ 6 07-07-2010 05:16 AM
How would you repair this hull damage? cosmoking Gear & Maintenance 13 05-07-2009 02:12 PM
Best way to repair this fiberglass damage? FishFinder Gear & Maintenance 11 04-20-2009 03:49 PM
Damage repair for winter storage, how? deckhanddave General Discussion (sailing related) 13 11-20-2006 07:47 AM
