Teak rudder for a Catalina 22...Pros and Cons - SailNet Community
post #1 of 13 Old 06-02-2012 Thread Starter
I recently acquired an 85 Catalina 22 and am in the process of getting her ready for the water. I have ran across a teak rudder that is almost the same dimensions as the factory one and was wondering what everyones thoughts are on putting it on such a boat. It is in good shape from what I can tell from the pics but I'm sure it will need sanding and some other type of treatment. I didn't know if it would need a certain type of sealant below the waterline or what. We have become members of the local yacht club and hope to be spending quite a bit of time on her when everything is ship shape so it will see lots of water. She will also be kept in a wet slip just as soon as one comes available but the rudder could be removed when we aren't using her. The cost of the rudder is considerably less than a new one and I think it would look awesome but just want to make sure it's not going to require a ton of maintenance. I would also like to hear any comments on performance or handling issues as I'm thinking once it gets wet and absorbs water the weight is gonna change. Thoughts?
copacetic is offline
post #2 of 13 Old 06-02-2012
One of None
deniseO30's Avatar
Re: Teak rudder for a Catalina 22...Pros and Cons
bad idea in my opinion. it will get soggy if left in the water long term. epoxy won't stick to it for very long so it's going to get slimy and heavy. Got a photo? New they go for $400 - to 700 depending where you get them. that much teak could be worth some money in of itself though. I can certainly think if better uses for the teak!
Catalina 22 rudders must going on the black market or something there seems to be an awful lot of people looking for them for their 22s!
My last project!
deniseO30 is offline
post #3 of 13 Old 06-02-2012 Thread Starter
The sogginess was my concern as well and I have no idea what is happening to them because I've been looking for a month or so now.
I am on a budget so new is not really what I'm looking for. On the other hand maybe I could buy the teak one, sell the wood, and buy a new one. The guy seems to think the teak holds a substantial value itself.
post #4 of 13 Old 06-02-2012 Thread Starter
Here's a pic...
post #5 of 13 Old 06-02-2012
emoney's Avatar
If it's the same dimensions, and a good enough buy, why not? Make sure it's the same
length in the water because that will be important for steerage. But, obviously it's been
a rudder up until now, so someone felt like it was good enough for that purpose.
emoney is offline
post #6 of 13 Old 06-02-2012
One of None
deniseO30's Avatar
Guess it all comes down to what you want to pay.
that piece of wood is nothing like the original (imho)
there there's this.. I've seen these, and they are nice.
My last project!
post #7 of 13 Old 06-02-2012 Thread Starter
That is definitely sweet lookin' but comes with a sweet price too. It looks similar to the ones on Catalinadirect but this one looks better.
I really think I would like the versatility of a kick-up rudder better but the teak one isn't too far away and it could possibly get me in the water sooner. I guess I could use it until I found a used kick-up then would have a spare.
Here is a plain jane C22 rudder I found....I've got the dimensions for the original and they're close. The teak one is maybe 2" longer.
Is there any type of clear epoxy that could be applied that would hold up under water?
post #8 of 13 Old 06-02-2012
I had some experience with a teak rudder on my Wayfarer, although that was teak ply.
The best rudder for a Wayfarer is considered to be composite : plywood covered in fibreglass. So what I would do with your rudder (and did with mine) is cover it with epoxy. You can apply a layer of glass then epoxy, but I just went with epoxy, no glass.
I painted West System Epoxy onto mine, with a brush. You get a surprisingly smooth finish. Do one side, keeping it horizontal, then do the other when the epoxy has set. Add a couple of layers and sand lightly. Then you need to add a few layers of spar varnish for UV protection.
However, I don't think a teak rudder is a good solution for a boat left on a slip. I think water will find a way in. Remember the lower edge of rudders tends to get chipped by debris or the bottom, then you have broken the epoxy seal and water gets in.
MarkSF is offline
post #9 of 13 Old 06-03-2012
paulk's Avatar
People have used wooden rudders for a long time. (Any Egyptians, Greeks or Phonecians out there?) Water absorption did not seem to be a major issue to them or to subsequent users. If this one fits, and the price is right, paint it with antifouling and go for it. Treatments like epoxy are likely overkill, and may have adhesion problems. You would need antifouling on top of any epoxy in any case, to keep marine growth down. Teak seems to last well, even in constant submersion. With antifouling to keep the toredos away, it might last 15 or more years -- unless you hit something with it and it pulls the transom off. (Teak is pretty tough stuff.)
paulk is offline
post #10 of 13 Old 06-03-2012
Senior Moment Member
SloopJonB's Avatar
Go for the teak and just varnish it - lots of coats of good spar varnish. I had a varnished mahogany rudder on my first 20 footer and it was a thing of beauty and didn't absorb water. Teak would be even better.
I did unship it and store it below when docked, which helped to keep it nice.
SloopJonB is online now
Catalina 38 pros and cons SimonV General Discussion (sailing related) 70 04-12-2015 06:01 PM
teak decks... pros and cons divesailor Gear & Maintenance 23 04-09-2007 11:08 PM
Catalina 38 pros and cons SimonV Boat Review and Purchase Forum 3 08-01-2006 11:28 AM
Catalina 38 pros and cons SimonV Catalina 0 07-18-2006 10:23 PM
