Combo anchor & steaming light - SailNet Community
 7Likes
post #1 of 28 Old 06-03-2012 Thread Starter
jarcher's Avatar
Hi All...
I'm looking for a masthead light that is both an anchor light and a steaming light. Perhaps something similar to the OGM tri color / anchor, where there are a few LEDs int here but the housing is partitioned?
I like my OGM light quite a bit, but I am going to a much smaller mast head and there is just no room for it. So its going to a friend, and I'm in search of a smaller light.
Thanks!
Helios
Scampi 30 MK-IV
jarcher is offline
post #2 of 28 Old 06-03-2012
Re: Combo anchor & steaming light
Steaming lights and anchor lights are at different places on the boat, they can't be combined.
A steaming light should be placed 1/2 to 2/3 of the way up the mast. While an anchor light should be at the very top of the boat. Other than electrically they are independent systems.
seabeau likes this.
Stumble is offline
post #3 of 28 Old 06-03-2012
KNOT KNOWN
Capt.aaron's Avatar
A steaming light is also only vis from 180 deg ( sorry, 225 deg).any way's, An anchor light need's 360 deg. vis. You should have an anchor light that comes on automatically when the sun goes down. Also, when it's on the mast head sometimes it blends in with the stars for a fast moving skiff. I hang mine low, 10 feet above my bimini. There is a mlia sec. when it's obscured by the mast from head on, but it illuminates the boat so you can still see it.
" Some are boat wise and some are other wise"
Capt.aaron is offline
post #4 of 28 Old 06-03-2012
mitiempo's Avatar
A steaming light is 225 degrees
Capt.aaron likes this.
Brian
mitiempo is offline
post #5 of 28 Old 06-03-2012
KNOT KNOWN
Capt.aaron's Avatar
Indeed, excuse me.
post #6 of 28 Old 06-03-2012
Cal28's Avatar
After much investigation and research (and waiting for production) ... just got this from LunaSea at Strictly Sail Pacific ...Tri-Color/Anchor/Stobe LED Waterproof Navigation Fixture
might work for you ...
"It is only with the heart that one can see rightly; what is essential is invisible to the eye."
Antoine de Saint-Exupery
Cal28 is offline
post #7 of 28 Old 06-03-2012
geehaw's Avatar
Steaming/masthead lights can be on the top of the mast. Here is a link to a combination masthead/anchor light Perko, Masthead, All Around Light, Combination, 12v Volts There are others out there too.
geehaw is offline
post #8 of 28 Old 06-03-2012
mitiempo's Avatar
You can actually do this with a single all round anchor light at the top of the mast combined with the red/green lights. But you cannot use a stern light with this as the anchor light replaces both the steaming and stern light.
Colregs allows this, but it is seldom seen.
And you would still need a stern light when under sail.
Tempest likes this.
Brian
mitiempo is offline
post #9 of 28 Old 06-03-2012
tdw
Super Fuzzy Moderator
tdw's Avatar
How do Col Regs allow for this or am I misinterpreting your post ?
Andrew B (Malö 39 Classic)
― Terry Pratchett.
tdw is offline
post #10 of 28 Old 06-03-2012
KNOT KNOWN
Capt.aaron's Avatar
Ya, he's right, I remember something like that on one of my rules test's.
Tri-color Steaming masthead light as only nav light? Perithead Gear & Maintenance 110 09-18-2011 12:53 PM
steaming light, running light, wiring yzlian Pacific Seacraft 4 03-24-2011 09:44 AM
'76 Pearson 26 steaming light: what bulb? fendertweed Gear & Maintenance 12 05-20-2009 08:23 AM
Steaming light wchevron Gear & Maintenance 13 05-17-2009 10:49 AM
Steaming light zz4gta Gear & Maintenance 3 04-30-2008 11:45 AM
