06-04-2012
Re: Worn Prop Shaft
We just replaced the prop shaft on Abracadabra. We had our yard do it. There's a lot of things on the boat I'm not afraid to tackle, but, especially being as this required dropping the rudder, this was not one of them. We don't have the final bill yet, but they quoted about $1000 to: - Drop the rudder (boat had to be in the slings for that)
- Remove prop, old prop shaft, flange and cutlass bearing
- Have new prop shaft made, plus repair/replace/recondition coupling flange, as-needed
- Install new cutlass bearing
- Install new prop shaft
- Install new zinc
- Reinstall prop
- Align engine with prop shaft
- Re-install rudder
- Splash and check alignment
- Adjust reversing gear ("transmission" for you non-A4 sailors
- Test
Boat now does over 7 kts on the iron genny, even with some wind on her nose, with the ol' A4 sounding happy as a clam and running at lower RPM than it used to to get us to 6 kts  . It was worth it.
Old bronze prop shaft was bent, out-of-round, and exceedingly worn due to misalignment with the engine. Cutlass bearing was shot, too.
Jim
