First time bottom painting - Page 2 - SailNet Community
post #11 of 45 Old 06-04-2012
I don't discuss my member
Fstbttms's Avatar
Re: First time bottom painting
Originally Posted by CalebD View Post
I'd recommend an ablative paint as well for brackish water. Barnacles can be a real bytch to remove and an ablative or 'soft' paint helps minimize their forming.
Both ablative and hard paints are equally effective at repelling barnacles. But the OP doesn't have a choice about what type of anti fouling paint to use. Because he plans to keep the boat out of the water for 6 months at a stretch and hard paints cannot withstand extended periods exposed to air, he must use an ablative paint.
Fstbttms is offline
post #12 of 45 Old 06-04-2012
Thought Petit Vivid was a multi season hard paint.
Jeanneau 54DS
Minnewaska is offline
post #13 of 45 Old 06-04-2012
Fstbttms's Avatar
It's a "hybrid" paint that has some attributes of both ablatives and hard paints. In practice, in the water, it's as easily removed as any ablative, maybe more easily. According to Pettit, it can be used successfully on dry-sailed boats.
Fstbttms is offline
post #14 of 45 Old 06-04-2012 Thread Starter
JMN412's Avatar
And the ablative paint will hold up in salt water as well?
JMN412 is offline
post #15 of 45 Old 06-04-2012
Fstbttms's Avatar
Well, it would help to know what specific product you had in mind, but yes, most paints are designed for use in saltwater.
Fstbttms is offline
post #16 of 45 Old 06-04-2012
I am in the process of restoring a macgregor Venture 25 and I am going to attempt to paint thebottom this week. Does anyone know how many gallons a 25 foot boat needs? Is there an advantage to doing more than one coat? Any general tips will be much appreciated.
Thanks
I just painted the bottom of my MacGregor 25 last week and I used the other half of the gallon of and still have a little left over. Two quarts is more than enough. As for how many coats..........well, one is enough. When it wears off put another one on. Each coat will last a year.
When cleaning the bottom in mid season, use a plaster knife (10") to scrape off slime and such. Do not scrub the bottom.
Jim
jentine is offline
post #17 of 45 Old 06-04-2012
Fstbttms's Avatar
Take it from someone who cleans boat bottoms for a living- this is bad advice. Clean your hull when it is lightly fouled and use carpet or a white Doodlebug pad. Never use anything hard or edged on your anti fouling paint unless necessary to remove hard growth.
Fstbttms is offline
post #18 of 45 Old 06-04-2012
dnf777's Avatar
Fstbttms:
You ticket to eternal fame is to write a brief summary of bottom maintenance for the articles forum! I'll be first in line to read it.
dnf777 is offline
post #19 of 45 Old 06-04-2012
Fstbttms's Avatar
Originally Posted by dnf777 View Post
Fstbttms:
Ugh! An essay? I hate homework.
Fstbttms is offline
post #20 of 45 Old 06-04-2012
Cool Re: First time bottom painting
Think of it as a cheat sheet for those of us who don't know what we're doing.
momclarissa is offline
Tags
maintenance , paint , restore
Bottom Painting, Where do I start...? Squidd Gear & Maintenance 15 11-20-2011 07:45 PM
?'s before painting my bottom. Perithead Gear & Maintenance 1 03-28-2011 09:42 AM
Painting Time again - My Bottom DrB Gear & Maintenance 8 04-12-2010 12:41 AM
Painting the Bottom of our Sailboat catalina30alyssa Gear & Maintenance 3 04-22-2009 12:27 PM
bottom painting lat38col36 Racing 2 01-21-2003 05:53 PM
