First time bottom painting - Page 5 - SailNet Community
post #41 of 45 Old 06-07-2012
Badger Sailor
MSN2Travelers's Avatar
Arrow Re: First time bottom painting
Originally Posted by Fstbttms View Post
Your post did little to clear up any confusion. FYI to anyone who remains unclear on the definition- "Bottom paint" is anti fouling paint. Two terms for the same thing. "Bottom paint" does not refer to an epoxy barrier coat, which is not a "paint" of any kind.
I guess I have run into a few first-time boat owners that think anything you put on the underside of a boat is "bottom paint". I've seen more than one person ask what brand/type "bottom paint" will help prevent blisters on a new boat.
I think it's pretty clear that JMN412 doesn't know what kind of "paint" he is sanding off. Asking if he is sanding down to barrier or gelcoat will go a long way in helping us give good advice. Do you think he knows the difference?
Paul
`99 Beneteau Oceanis 352, #282 WiTCHCRAFT
Milwaukee, WI
Sailing Lake Michigan and the Great Lakes
MSN2Travelers is offline
post #42 of 45 Old 06-07-2012
I don't discuss my member
Fstbttms's Avatar
Perhaps not. But suggesting that an epoxy barrier coat also be called "bottom paint" is not going to enlighten him.
Fstbttms is offline
post #43 of 45 Old 06-07-2012
tap
The paint itself will likely have lots of nasty fumes. This isn't latex house paint your dealing with here. All the information about it should be on the can. You need something with an organic vapor filter. A dust mask doesn't have that and won't do you a bit of good.
They sell several different masks that their 6001 organic vapor cartridges go onto. Some are cheaper than the 7500 masks like I posted and some are more expensive full face masks. I found this stuff to be rather pricey at hardware stores and bought it from an ebay seller. Something this:
3M Dual Cartridge Respirator Assembly,Organic Vapor/P95 Large #7193 | eBay
or this:
3M 5203 DUAL CARTRIDGE HALF-FACE RESPIRATOR MEDIUM Organic Vapor - Acid Gas NEW | eBay
tap is offline
post #44 of 45 Old 06-07-2012 Thread Starter
JMN412's Avatar
I know for certain that I am sanding down another layer of antifouling paint. I have the old paint can, and it is a pettit paint. But I am planning to use the West Marine CPP to paint over it.
JMN412 is offline
post #45 of 45 Old 06-08-2012
You might find this helpful, but I think some are optimistic.
http://content.westmarine.com/docume...t_2012.xls.pdf
Jeanneau 54DS
Minnewaska is offline
Tags
maintenance , paint , restore
Bottom Painting, Where do I start...? Squidd Gear & Maintenance 15 11-20-2011 08:45 PM
?'s before painting my bottom. Perithead Gear & Maintenance 1 03-28-2011 10:42 AM
Painting Time again - My Bottom DrB Gear & Maintenance 8 04-12-2010 01:41 AM
Painting the Bottom of our Sailboat catalina30alyssa Gear & Maintenance 3 04-22-2009 01:27 PM
bottom painting lat38col36 Racing 2 01-21-2003 06:53 PM
