Oil Scare - Universal M25 - Page 2 - SailNet Community
post #11 of 28 Old 06-04-2012 Thread Starter
Learning the HARD way...
eherlihy's Avatar
Re: Oil Scare - Universal M25
Originally Posted by JimMcGee View Post
I seem to remember reading about problems with the oil pressure relief valve on another site (may have been the C34 tech wiki at C34.org or on SailboatOwners.com). The problem was similar to yours but I can't find the link right now...
Probably the Ericson Owners Group... See thread here; Oil pressure problem?
Also note that I already checked the valve, and it is clean. I may replace the spring, as pointed out in the Ericson forum.
Because the pressure is better since the oil change, I strongly suspect the viscosity of the oil that I added last fall did not match what the package said.
Another tid-bit to chew on; the engine water temp never went over 180.
eherlihy is online now
post #12 of 28 Old 06-04-2012 Thread Starter
eherlihy's Avatar
...and for the guy in the Ericson forum that couldn't find the relief valve, here it is;
post #13 of 28 Old 06-04-2012
Senior Cruiser
sea_hunter's Avatar
For low rpm check your air intake, the screen or filter may be blocked. You might have a faulty op sender if the alarm didn't go off especially if the temp didn't rise. 10m is fine for the filter, but I'd be looking for something simple first.
sea_hunter is offline
post #14 of 28 Old 06-04-2012
JimMcGee's Avatar
That wasn't the thread but the info is the same. Evidently this problem is not uncommon on Universals.
FWIW the C34 tech wiki at c34.org has a lot of good info on these engines.
95 Catalina 30 Island Time
The sail, the play of its pulse so like our own lives: so thin and yet so full of life, so noiseless when it labors hardest, so noisy and impatient when least effective." - Henry David Thoreau
JimMcGee is offline
post #15 of 28 Old 06-04-2012
If changing to a different oil solved the problem the original oil viscosity must have been WAY off from what was printed on the label?
Paul T
dabnis is offline
post #16 of 28 Old 06-04-2012
Forgot this, if the crankcase was overfilled perhaps the crank was turning the oil into froth?
Paul T
dabnis is offline
post #17 of 28 Old 06-04-2012
One of None
deniseO30's Avatar
E, I don't know where I read it but someone had the wrong oil filter and after installing the right type the oil pressure returned. I'm guessing that happened to you.
My last project!
deniseO30 is offline
post #18 of 28 Old 06-04-2012
Maine Sail's Avatar
Are you sure the Motorcraft oil was a "C" rated oil not an "S" rated? I know Motorcraft makes one but I know my local Wal*mart does not carry it.
I have one word for diesel oil..... ROTELLA T !!!
Top End Rotella T Exclusively Since New:
And the hours when the pic was taken:
______
-Maine Sail / CS-36T
Maine Sail is offline
post #19 of 28 Old 06-04-2012 Thread Starter
eherlihy's Avatar
That is a great idea, and I shall check the air intake...
However the engine will hit 3K RPM in neutral, but not under load...
I am fairly confident that the oil pressure sender is working as it should.
post #20 of 28 Old 06-04-2012 Thread Starter
eherlihy's Avatar
Yes, I have the C36, C34 and C30 websites bookmarked on my home computer. I am on a business trip this week in Chicago without my personal laptop. (Will I ever be able to retire, and do what I love, instead of having to do what other people want?)
The Ericson owners group is also a good one. A couple of well known posters from this forum used to hang out there.
My biggest boating scare randomforumname General Discussion (sailing related) 14 03-02-2012 05:29 PM
Sailing: Shark not only scare for Wright NewsReader News Feeds 0 12-07-2011 01:40 PM
seacock scare sailingtime Gear & Maintenance 4 07-22-2009 11:22 AM
Eagles survive scare (The Charleston Gazette) NewsReader News Feeds 0 03-01-2007 01:15 AM
