Depth meter - SailNet Community
post #1 of 10 Old 06-04-2012 Thread Starter
Depth meter
The depth meter on my boat doesn't work - it turns on, but the reading jumps from 10ft to 180ft. I want to fix/change it.
With the readings like this - do you think the problem is with the depth meter itself or with the transducer?
It is round shape, mounted to the right of the entrance door.
Romario is offline
post #2 of 10 Old 06-04-2012
Re: Depth meter
Going to need a few more details than just "round" and where it's mounted. Is it your xducer that's round or your gauge? Make? Model?
Ericson 381
McGinnis is offline
post #3 of 10 Old 06-04-2012 Thread Starter
Re: Depth meter
I should have taken a picture, don't remember unfortunately. Let me see if I can find it. I think it was two words and one of them was "marine" or similar, but I don't remember exactly.
The gauge is round.
Romario is offline
post #4 of 10 Old 06-04-2012
Re: Depth meter
Likely a Datamarine unit... from 30+ years ago. Mine did the same so I picked up a Raymarine ST60 unit on eBay for ~$150 and called it good. Now I just need to haul out and put the ducer in.
If you want my old head unit, ducer or control panel send me a PM.
Ericson 381
McGinnis is offline
post #5 of 10 Old 06-04-2012 Thread Starter
Re: Depth meter
Yes, looks like this:
http://www.sailingseadragon.com/Manu...rineS200DL.pdf
it has 8ft/4ft/off switch in front like the picture in the manual.
Can I reuse the transducer? Or they are not interchangeable (probably not :-) )? Does it mean I would need to get the boat out of water to put the transducer?
Romario is offline
post #6 of 10 Old 06-04-2012
Re: Depth meter
Same unit that I had, did the same thing too. From what I know, the ducer isn't interchangeable but honestly I never really looked into it.
Best bet is to haul out. It may be your only bet too. I've heard of owners drilling through the hull while a diver is below. 5200 does setup underwater!
Ericson 381
McGinnis is offline
post #7 of 10 Old 06-04-2012 Thread Starter
Re: Depth meter
So, what depth finder should I get? What is the difference - they wary in price wildly, from 85 to 800 dollars.
Should I get something fancier with gps, etc? Or maybe fishfinder, they seem to show the depth as well.
I saw some have transom mount, some have thru hull transducers - which should I chose? How transom mount works - does it mean that it sticks outside, or the hole should be drilled?
Romario is offline
post #8 of 10 Old 06-04-2012
Depth meter
If it is Signet Marine I had problems with my transducer cable. It was pinched and gave errant readings. Put on a removable transducer for $200, sealing the outer fixture with 3M 5200 and can remove it putting in a dummy plug provided!
ahab211 is offline
post #9 of 10 Old 06-04-2012
Junior member, rest old
msmith10's Avatar
Re: Depth meter
DMI Marine (google them) repairs Datamarine instruments. You may want to call them and see if there's a simple test procedure to determine if it's the transducer or the readout. I suspect they could repair the readout and you wouldn't have to do any hull work to change the transducer. Also, if it's the display, they frequently show up on ebay pretty inexpensive.
Mark Smith
1977 C&C 30 Mk 1 hailing from Port Clinton, Ohio
msmith10 is offline
post #10 of 10 Old 06-07-2012 Thread Starter
Re: Depth meter
I called the guys, they say it could be one or another, can't say when the data is erratic.
I have several questions:
1. Are the transducers compatible with one another or they are unique for each device?
2. If I am to replace the depth meter - is it better to reuse the same hole the old transducer was in or drill a new one? Is it hard to remove the old one?
Romario is offline
Digi-Depth 99 Depth Sounder sdumo Electronics 0 12-04-2011 02:06 PM
DC meter Dcneuro Bristol 3 07-19-2010 07:46 AM
Depth meter PaulinVictoria Gear & Maintenance 5 07-04-2010 03:27 PM
Amp meter? motion300 Electrical Systems 28 03-13-2010 07:46 PM
Knot meter and depth gauge. zz4gta Gear & Maintenance 8 11-09-2007 11:12 AM
