Winterizing - SailNet Community
Blogs
Old 01-05-2004
drynoc is on a distinguished road
Winterizing
JeffH mentioned on another string that he added Y valves to his engine to make it easier to winterize. I would love to hear more about this from anyone knowledgable on the subject.
Old 01-05-2004
obiec is on a distinguished road
Winterizing
It is real simple. On the inlet hose for your fresh water. Add a y valve with a small pice of hose. When you tern the valve so that the engine sucks from the small pice of hose you put the hose in a bucket with RV antifreaze in it an suck up a littal, mabe a half galon. and you are done winterizing. If you install a vetuse strainer you can just shut off your see calk and fill the strainer. Then re start the engine. it is real simple.
How much winterizing do I need? foxglove Gear & Maintenance 7 09-18-2004 01:22 PM
Winterizing For Cold Weather Ole_Sea_Dog General Discussion (sailing related) 8 01-14-2004 08:25 PM
winterizing the rig jurpo Gear & Maintenance 1 09-11-2003 07:36 AM
Winterizing - Need advice rookie00 Gear & Maintenance 1 10-29-2002 05:20 AM
SEO by vBSEO 3.6.0
(c) Sailnet 2000-2006
