Sealant recomendation - Page 2 - SailNet Community
post #11 of 13 Old 06-04-2012
Seattle Sailor
Re: Sealant recomendation
I also recommend Butyl tape for this job, since the window will be held in place by the bolts, and the sealant has only to form a tight and resistant seal. Using any of the silocone caulking gets a lot messier and is much harder to clean up. the tape can be trimmed to the window edge after installation very easily. Used it to rebed a deck cover window as well as most of my deck hardware. Easy to work with, and no mess. See Mainsail's site for helpful instructions.
PDean
CS 34
Seattle, WA
"The pessimist complains about the wind; the optimist expects it to change; the realist adjusts the sails." - William Arthur Ward
padean is offline
post #12 of 13 Old 06-04-2012
Best Looking MALE Mod
Cruisingdad's Avatar
I suggest GE silpruf SCS2000 for mecahnically fastned hatches or portlights. You can also use dow Corning 739 or Dow Corning 795, though they are probably an overkill for mechanically fastened PL/PH. My suggestion is the SCS2000. If you cannot easily find that,739.
Brian
Sailnet Moderator
My Website:
Follow My Blog at:
Follow me on Facebook:
Cruisingdad is offline
post #13 of 13 Old 06-04-2012 Thread Starter
jarcher's Avatar
Originally Posted by asdf38 View Post
Seconded. Buy it from MaineSail.
Bedding Deck Hardware With Butyl Tape.
I have used butyl tape in the past, and its great for some things, perhaps windows are a good use for it. I once used it on a travler track. Major mistake. As Mainesail said, it never hardens and remains sticky forever. It tended to get into the bearings of the traveler car, causing a major headache.
Helios
Scampi 30 MK-IV
jarcher is offline
SF Bay Bottom Cleaner Recomendation? sfbaysailing Gear & Maintenance 3 05-08-2012 11:57 AM
surveyor recomendation for North Carolina johnd59 Boat Review and Purchase Forum 8 09-24-2009 11:08 AM
which sealant to use LookingForCruiser Gear & Maintenance 5 07-09-2009 08:18 AM
Anyone have a toilet recomendation? jarcher Gear & Maintenance 17 04-05-2009 02:56 PM
Recomendation for multitester? 7tiger7 Gear & Maintenance 10 07-24-2007 11:59 PM
