Sealant recomendation - SailNet Community
post #1 of 13 Old 06-04-2012 Thread Starter
jarcher's Avatar
Hi All...
I need to rebed a window. The windows has bolts to hold it in, so I need a sealant, not an adhesive. A few years ago the best stuff used to be something made by 3M, but they discontinued it. At that point I went to Silkins, but that's very thin.
I know I could use butyl tape, but I am wondering what the current thinking is on the best non-adhesive sealant that is somewhat thick and has no silicon in it?
Thanks...
Helios
Scampi 30 MK-IV
jarcher is offline
post #2 of 13 Old 06-04-2012
the pointy end is the bow
erps's Avatar
Re: Sealant recomendation
I went through this last month. Resealed two glass windows. Google Boatlife polysulfide. Sticks well, remains flexible but it cures slowly. It attacks some plastics though.
BoatLIFE | LifeCaulk Sealants and Polysulfides
Ray
S.V. Nikko
1983 Fraser 41
La Conner, WA
erps is offline
post #3 of 13 Old 06-04-2012
Here is the 3m selection guide :
Marine Sealant & Marine Adhesive Guide : Marine Supplies : 3M Europe
Looks like they recommend 4400 according to the table.
There's also Life Seal, which is what I've been using lately. It's a silicon/polyurethane blend which cleans up easily with acetone. Despite having silicon in it, I've found no problems in areas where I've removed it and then painted - just cleaned with acetone first.
MarkSF is offline
post #4 of 13 Old 06-04-2012
Senior Cruiser
sea_hunter's Avatar
Sika- sandable and paintable - topsides or bottom. Better than any product on the market, especially 3M or silicone products.
sea_hunter is offline
post #5 of 13 Old 06-04-2012
I really am not clear when I should use LifeCaulk, and when I should use LifeSeal. Do you know the answer?
MarkSF is offline
post #6 of 13 Old 06-04-2012
Break, curse, fix, repeat
bwindrope's Avatar
I highly recommend butyl rubber for this and have done this on my own boat. Lots of threads on the subject.
Aeolus
Gulf 32
Bainbridge Island, WA
bwindrope is offline
post #7 of 13 Old 06-04-2012 Thread Starter
jarcher's Avatar
Yeah they do, but everything above 3200 is an adhesive, which I don't want or need. I really prefer not to use adhesives when there are mechanical fasteners holding things together. 3200 has silicon in it and I really don't like to use silicon based products.
That's a good point about making asure the sealant is compatible with the type of plastic. As I recall, there are two different types of plastics predominantly used for windows, and I need to use the right sealant. Problem is, I don't know which type of plastic this window is made from.
That might not be an issue though. The plastic window is sealed to a frame, and I don't think the leak is is between the plastic and the frame, but rather the frame and the boat. But I won't know until I get it apart and fill the window with water to see if it leaks.
Surely there is a sealant available that is non-adesive, thick and contains no silicon?
Helios
Scampi 30 MK-IV
jarcher is offline
post #8 of 13 Old 06-04-2012 Thread Starter
jarcher's Avatar
Sikaflex 291 would be my choice, except its very thin. Unless my memory is failing, it just runs all over the place.
Helios
Scampi 30 MK-IV
jarcher is offline
post #9 of 13 Old 06-04-2012
3M Ultra Glaze is what I used. Don't know if they still sell it but seals well and pliable. Is black and messy to work with, though!
ahab211 is offline
post #10 of 13 Old 06-04-2012
asdf38's Avatar
Seconded. Buy it from MaineSail.
Bedding Deck Hardware With Butyl Tape.
asdf38 is offline
SF Bay Bottom Cleaner Recomendation? sfbaysailing Gear & Maintenance 3 05-08-2012 11:57 AM
surveyor recomendation for North Carolina johnd59 Boat Review and Purchase Forum 8 09-24-2009 11:08 AM
which sealant to use LookingForCruiser Gear & Maintenance 5 07-09-2009 08:18 AM
Anyone have a toilet recomendation? jarcher Gear & Maintenance 17 04-05-2009 02:56 PM
Recomendation for multitester? 7tiger7 Gear & Maintenance 10 07-24-2007 11:59 PM
