Elbow for Fuel Tank Fill Hose - SailNet Community
 1Likes
  • 1 Post By tommays
post #1 of 9 Old 06-06-2012 Thread Starter
1979 C&C 30 MK1
flyingjib's Avatar
Hello Gurus,
I'm in process of installing a Moeller Polyethylene Diesel Fuel Tank in my C&C 30 MK1. The old aluminum tank had a fuel fill connector with a 90 degree elbow built in but the new tank doesn't come with an elbow and I don't have enough clearance to connect the fuel fill hose vertically. I was thinking of getting one of those flexible elbows with hose clamps from Home Depot and use a piece of PVC pipe as a coupler. Is there a better way to mend this situation? Any suggestion is greatly appreciated.
Cheers,
Aaron
flyingjib is offline
post #2 of 9 Old 06-06-2012
Courtney the Dancer
jrd22's Avatar
Re: Elbow for Fuel Tank Fill Hose
I would contact Moeller and ask about an elbow. PVC- not a good idea.
John
SV Laurie Anne
1988 Brewer 40 Pilothouse
jrd22 is offline
post #3 of 9 Old 06-06-2012
You could get the appropriate (a street elbow? NPT to hose nylon. to a female threaded outlet.))fitting put into the tank before installing. They are usually spun in and the friction welds them.
Capt Len is offline
post #4 of 9 Old 06-06-2012
72 C&C Corvette
CorvetteGuy's Avatar
I had the same problem with mine, and cant recall where I bought the 90 elbow but is was a soft black rubber which allowed me to use 2 gear clamps to attatch to the tank.
CorvetteGuy is offline
post #5 of 9 Old 06-06-2012 Thread Starter
1979 C&C 30 MK1
flyingjib's Avatar
Unfortunately they don't provide an elbow for their straight fill. How about a copper pipe and a rubber elbow instead?
post #6 of 9 Old 06-06-2012 Thread Starter
1979 C&C 30 MK1
flyingjib's Avatar
I'll look into this. Thank you.
post #7 of 9 Old 06-06-2012
tommays's Avatar
Trident Rubber 32911241B Fuel Corr. A2 1-1/2 x 12.5
How tight is the bend as the Trident is made for bendiing without kinking as i had to do some crazy stuff to move the fuel fill form the cockpit to the rail
flyingjib likes this.
1970 Cal 29 Sea Fever
1981 J24 Tangent 2930
Tommays
Northport NY
tommays is offline
post #8 of 9 Old 06-06-2012 Thread Starter
1979 C&C 30 MK1
flyingjib's Avatar
Thank you! This was exactly what I needed. My local shop had a similar product by Vetus. Worked just fine. I really appreciate it.
Cheers,
Aaron
post #9 of 9 Old 10-29-2012
Aaron...I am currently doing a similar "upgrade" to my boat, replacing an aluminum tank with a Moeller plastic. Gates Rubber makes a 90 degree rubber elbow that you can clamp on, various IDs (mine is 1 1/2" - Gates #24715)
Viking is offline
Tip to get Hose on bronze elbow SanDiegoChip Gear & Maintenance 21 09-08-2011 12:04 PM
Diesel Fuel Tank Fill & Vent casey1999 Diesel 12 04-20-2011 01:57 PM
Fuel fill hose yachtthor Pacific Seacraft 2 01-17-2010 05:12 PM
'68 M34 Water Tank Fill Hose Question dancrosswis Morgan 0 04-01-2006 03:07 PM
Fuel fill (pipe) to (hose) adapters pjfsail Gear & Maintenance 2 09-26-2004 10:30 AM
