dock box - SailNet Community
 1Likes
  • 1 Post By SVAuspicious
post #1 of 9 Old 06-06-2012 Thread Starter
dock box
This maybe a rookie question but I just bought my first dock box and I have been told that once I start putting things in it I will not need to secure it to the dock. This seems a bit odd, my gut tells me that I need to drive a couple of screws with washers through the bottom of the box and into the planks of the dock. So I am wondering, what others have done to secure their box to the dock?
sailingtime is offline
post #2 of 9 Old 06-06-2012
Junior member, rest old
msmith10's Avatar
Re: dock box
L-angles bolted to the box then lag bolted into the dock.
Mark Smith
1977 C&C 30 Mk 1 hailing from Port Clinton, Ohio
msmith10 is offline
post #3 of 9 Old 06-06-2012
Pearson 303
SVCarolena's Avatar
Re: dock box
Yes, you need to secure it if you want it to stick around. A good wind, someone weaving down the dock bumps into it, and not only have you lost your expensive box, but also the contents. Ours had holes predrilled in the bottom to screw it to the dock, and the screws had rubber washers to keep the water out. The other suggestion of l-brackets would also work. Either way, screw it down before you leave it sitting on the dock. Our dockmaster lost two into the drink because they were sitting on the dock while he was installing them. He went to his workshop to get some extra screws, and by the time he returned, two of them had blown into the drink.
SVCarolena is offline
post #4 of 9 Old 06-06-2012
Re: dock box
Sailing,
It also depends on where you are. Here in Louisiana an unsecured dock box is guaranteed to go floating the next time a hurricane comes through and the water rises.
Greg
Stumble is offline
post #5 of 9 Old 06-07-2012
Re: dock box
There's only one thing you should be putting in your dockbox (es)! And dockboxes usually don't actually go out on to the dock....
OH.
I thought you were talking about the kind of "DockBox" that is high maintenance.
You know, the nails, the hair, won't go out on a race boat but shows up at the party afterwards...
NEVER MIND.
CS 36M DIANTHUS
sailordave is offline
post #6 of 9 Old 06-07-2012
Mermaid Hunter
SVAuspicious's Avatar
Re: dock box
Through bolt. It's worth the time hanging over the edge of the dock. Should be at least four, 1/4" or bigger with fender washers above and below.
You'll probably end up wanting to drill some drainage holes in the bottom of the box. The lid seals aren't what you would like them to be, and if you keep gasoline in the box the additional ventilation will be valued.
Be sure there is 1. room for full-size dock carts to get down the dock and 2. you can route your dock lines properly before you drill a bunch of holes and bolt things down. The former (inadequate room for carts) will really make you an unwelcome neighbor on the docks and a poor reputation with marina management.
chef2sail likes this.
SVAuspicious is offline
post #7 of 9 Old 06-07-2012
Sundance 23
carl762's Avatar
Re: dock box
I used screws and washers, and I drilled drainage holes. She's staying put.
Water is Life
carl762 is offline
post #8 of 9 Old 06-08-2012
chef2sail's Avatar
Re: dock box
Like S/V Auspicious said lag boplts and large washers on both sides. Sometimes high tides during storms or surges can cover the docks and you dot want it floating away.
Ditto on the drainage holdes. We kkep some paints, chemicals in ours and not only need a place fopr the fumes, but want a place to easily clean it and drain. Alsoif it doies flood it wont pop off the dock but fill with a little water.
Dave
___________________________
C&C 35 MKIII Hull # 76
Parkville, Maryland
(photos by Joe McCary)
Our blog-
chef2sail is offline
post #9 of 9 Old 06-08-2012
sevseasail's Avatar
Re: dock box
In my marina you have to have them (marina personnel) secure it, they will place it anywhere you like, but they do not want anybody drilling a bunch of holes to their docks.
Ask before you do it yourself...
S/V Chata
1980 Catalina 22
"Common sense is the least common of the senses"
sevseasail is offline
How would you dock her? jaminotte Seamanship & Navigation 17 03-01-2013 09:59 PM
Looking for a dock . . . dalraidia General Discussion (sailing related) 1 08-21-2010 07:36 PM
1/10/07 Was a bad day on our dock...... SVDistantStar General Discussion (sailing related) 5 01-11-2007 09:02 PM
Bullimore in dock (The Age) NewsReader News Feeds 0 11-21-2006 10:15 AM
Cats on the Dock Sue & Larry Cruising Articles 0 05-31-1999 09:00 PM
