Yay or nay on Norcold box conversion unit? - SailNet Community
Chat
Advertise Here
Go Back   SailNet Community > On Board > Gear & Maintenance
Like Tree14Likes
Old 06-06-2012
deniseO30's Avatar
1934 Chickering
I've been lugging ice for too long. Those of you that have the Norcold SCQT4407 box conversion unit how do you like it?
Being in the hvacr biz all my life has me thinking too much. it's on sale at Defender for a great price, WHICH is the motivation to get it soon!
SCQT 4407
Denise, Bristol PA, Oday 30. On Tidal Delaware River, Anchor Yacht Club. New Website!
My boat is for sale.
Reply With Quote Quick reply to this message Share with Facebook
  #2
Old 06-06-2012
msmith10's Avatar
Junior member, rest old
msmith10 is on a distinguished road
Re: Yay or nay on Norcold box conversion unit?
Yay.
For those who prefer an icebox, or for times when you're afraid of using too much of your battery reserve, you can always use ice. The evaporator doesn't take up that much space. On my boat the autopilot is much more of an energy hog than the fridge. I cool the fridge down as far as it will go while on shore power, then turn the thermostat up or off when sailing to save battery. That is a great price. Almost makes me wish my old one would break.
Mark Smith
1977 C&C 30 Mk 1 hailing from Port Clinton, Ohio
  #3
Old 06-06-2012
misfits is on a distinguished road
Yay, you gotta have refrigeration. Ice is for cocktails
Once you install this system you can still lug ice if you're concerned about battery capacity. You just won't need to lug as much of it or as often.
I'm not happy unless I'm complaining about something.
I'm having a very good day!
  #4
Old 06-06-2012
deniseO30's Avatar
1934 Chickering
or gets some of those $$$ vertical ice cube trays LOL
  #5
Old 06-07-2012
tomperanteau's Avatar
Crotchety Old Member
tomperanteau is on a distinguished road
Yay.
I installed one almost a year ago. We've had it running for as long at the docks so that we don't have to lug eggs, salad dressing, and other things, to the dock every weekend. It works great. It only draws 3 amps while running, and if you are insulated well, that won't be very often.
I bought ours at West Marine, which was competitive when I considered the shipping. It was easy to install (about 4 hours after the planning) and was straight forward. Well worth the $650 or so we spent.
Capt'n Tom Living Aboard 50/50
S/V Footprints
Youtube
1978 41' Morgan Out Island Sloop. Refitting and redoing her interior for an extended voyage.
1969 Crealock/Columbia 36 Sloop completely refitted in 2000 and new Yanmar in 2006. (for sale)
  #6
Old 06-07-2012
SchockT's Avatar
SchockT is on a distinguished road
If you are in the trade you should consider installing a custom system rather than one of those DIY kits. (or at least modifying the kit). The precharged lineset is usually much longer than it needs to be, leaving you with a coil of copper to deal with. The quick couplers will inevitably leak down the road, so why not hard pipe it if you have the skills? I can't see what kind of compressor that unit is running, but Danfoss is the one you want. Their compressors are extremely efficient, multi voltage and variable speed.
I used to install custom refrigeration systems, and I bought all the components from Nova Kool; Condensing unit, evap plates, cap tube and thermostat. Then you also have the option of going with different evaporator plates instead of having to make the one L-plate work. That may work in your ice box, but some it doesn't fit so well. I used to use 2 smaller plates to make a freezer compartment within the box. On a friends boat we were even able to serve ice cream on a hot day!
rikhall and Familycruisers like this.
  #7
Old 06-07-2012
deniseO30's Avatar
1934 Chickering
Schockt, I've allot of "junk" evaps and all kinds of refrigerants to play with. Sometimes it's just good to get something new. Agreed, Danfoss is the last word in 12volt compressors. Norcold does run a close 2nd. I do wonder, who makes Norcold's compressors? Quick connects leak? Not my experience. a drop or two of R oil makes the difference though.
The danfoss cu-84 is also has my attention.
12 ft of copper isn't a problem either.. will get the condenser closer to the battery banks. I know how precise the charge is and see no reason to change the ease of the installation.... brazing,,, nitrogen.. evac... charging.
  #8
Old 06-07-2012
SchockT's Avatar
Fair enough. If you aren't prepared to put in the effort, or don't have the skills and equipment to customize a system, by all means, put in a kit! They are a relatively cheap and easy solution.
I'll admit it was very early in my career that I was installing and repairing boat systems. These days I only do it for friends and fellow club members. Having said that, I would say the leading cause of refrigerant leaks in my experience, has been mechanical connections such as quick couplers. For that reason I am a big fan of hard piping systems. Of course if someone is paying a technician shop rates to do the job it can be expensive.
  #9
Old 06-07-2012
ccriders is on a distinguished road
Denise,
I just clicked on the link you provided and the info does not indicate this unit is for "marine" installation. Can that matter for condenser unit?
John
  #10
Old 06-07-2012
deniseO30's Avatar
1934 Chickering
Geeze Schockt this is not a competition, stop trying to bait me into a wizzing contest of skills and knowledge. I'm sure you are the greatest tech there is because you need to tell me
CC, all the 12volt units are not in my opinion "marine" since they all have plenty of painted steel. copper and aluminum, stainless never was a great conductor for DX coils.
chef2sail likes this.
You may post attachments
You may edit your posts
Norcold Refrigerator Conversion tomperanteau Cruising & Liveaboard Forum 11 10-15-2011 12:03 PM
Norcold Conversion Kit tomperanteau Cruising & Liveaboard Forum 7 05-21-2011 11:33 AM
Warning on Norcold DE-0061R Refrigerator stuartbell Gear & Maintenance 0 09-30-2008 12:36 PM
Norcold vs isotherm fridge wchevron Gear & Maintenance 10 08-30-2008 10:32 PM
norcold seac Gear & Maintenance 0 06-09-2003 07:23 AM
Copyright ©2000 - 2015, vBulletin Solutions, Inc.
SEO by vBSEO 3.6.1
The SailNet.com store is owned and operated by a company independent of the SailNet.com forum. You are now leaving the SailNet forum. Click OK to continue or Cancel to return to the SailNet forum.
