Yanamar 4JHE Impeller Replacement - SailNet Community
post #1 of 3 Old 06-07-2012 Thread Starter
Does anyone have any suggestions on accessing the four bolts on the port side of the engine in order to replace the impeller short of removing the alternator?
Any suggestions would be appreciated.
George
sachemgfp is offline
post #2 of 3 Old 06-07-2012
Sailing to surf
Beersmith's Avatar
Re: Yanamar 4JHE Impeller Replacement
George
they really put it in the worst possible place didn't they?
You can get to the bolts, it is just tricky and takes some positioning.
your two choices are to either get behind it like this:
or lay down a cushion on top and lie over it like this:
this is what it looks like with the cover off. You should have plenty of clearance to get wrenches back there
I am rebuilding the engine right now (4JH2E), if you want to check it out see the link in my signature.
My boat rebuild/sailing blog:
Beersmith is offline
post #3 of 3 Old 06-07-2012
I hope your buddy doesn't bump the stair hatch cover!
ambianceack is offline
Impeller replacement problem deborahmaas Diesel 9 08-16-2011 01:23 AM
yanmar 4JHE SVRovia Diesel 2 04-04-2011 11:09 PM
Impeller hrs sailrmon Gear & Maintenance 21 08-05-2010 10:45 PM
Prop Size for Crealock 37 w Yanmar 4JHE MarcHall Pacific Seacraft 0 07-19-2010 10:58 AM
Impeller replacement on westerbeke sailortjk1 Gear & Maintenance 10 07-16-2007 07:44 PM
