Outboard Issues - Page 2 - SailNet Community
post #11 of 14 Old 06-13-2012
Re: Outboard Issues
So I should squeeze the ball when running??
mike27' is offline
post #12 of 14 Old 06-13-2012
Fishin' from a Sailboat
Re: Outboard Issues
When it's about to die squeeze the bulb a few times. If the motor perks back up it will tell a lot that can be used to narrow down the problem.
My bet is a clogged filter, bad vent or sucking air in the fuel line. I doubt it's the carb. If you have another tank/hose try that out...borrow from a friend if possible.
HarborRat is offline
post #13 of 14 Old 06-13-2012
Re: Outboard Issues
Wow, this sounds familiar, including taking it back to the dealer. I finally solved my problem by replacing all the lines, the bulb, the filter and fittings. When I say replacing the lines this including the one inside the fuel tank, the lines & clamps on the motor and all the hard connections at the motor and tank.
I have not had a problem since, but I still find myself squeezing the bulb in those places where you dread to have the motor die.
I have a Tohatsu 6 hp, which I believe is the same motor.
suds45 is offline
post #14 of 14 Old 06-13-2012
Outboard Issues
Coils be overheating if your impeller is shot or affecting your water pump. Check your water discharge flow.
ahab211 is offline
2 issues with outboard SpeedAgent Gear & Maintenance 9 02-04-2009 12:00 AM
jib issues Loualfr Gear & Maintenance 3 06-25-2008 11:55 PM
C&C 115 Issues? mr_lucky Boat Review and Purchase Forum 4 11-05-2007 08:34 PM
Domestic Issues Tom Wood Cruising Articles 0 10-13-2001 08:00 PM
Domestic Issues Tom Wood Her Sailnet Articles 0 10-13-2001 08:00 PM
