Best of the bad choices- re-bedding chainplate cover - SailNet Community
 2Likes
  • 2 Post By bljones
post #1 of 9 Old 06-13-2012 Thread Starter
I don't live anywhere near a store that carries life seal or 3m 4200, my choices are Marine Amazing goop, 3m 5200, or a hardware store silicone. What would be best.
bscriver is offline
post #2 of 9 Old 06-13-2012
bljones's Avatar
Re: Best of the bad choices- re-bedding chainplate cover
point and click to Defender and order a couple of tubes of 4200.
3M Marine Adhesive / Sealant Fast Cure 4200
You've waited this long to do the job, you can wait a couple more days for the right stuff to arrive in the mail.
mitiempo and Jgbrown like this.
It's 5 o'clock somewhere:
bljones is offline
post #3 of 9 Old 06-14-2012
Or mainesail's Butyl tape. :-)
Jgbrown is offline
post #4 of 9 Old 06-14-2012
Of that lot the best is 5200. The problem will be one day in the future when you need to replace those covers. They will be effectively welded to the deck! 4200 is more suitable for anything that might one day be removed.
MarkSF is offline
post #5 of 9 Old 06-14-2012
asdf38's Avatar
Even 4200 can be more agressive than necessary. Like many applications adhesion isn't a requirement for chainplates (the sealant isn't holding in the chainplates!) but flexibility is. I think polysulfide or butyl tape is idea for chainplates. Don't go near the 5200 or you, or some poor future owner will be cursing you.
Read this. This is written by SailingDog
Adrift at Sea Marine Sealants in a Nutshell
But yes I agree it's worth putting in an order to get the right stuff. Don't just settle for what's in the hardware store.
asdf38 is offline
post #6 of 9 Old 06-14-2012
bljones's Avatar
I'm not a big fan of butyl for chainplate covers because of the ooze-out factor. for clearts toerails, lights, great, but for exposed, unflanged horizontal surfaces, i like something that sets and cures, like 4200.
bljones is offline
post #7 of 9 Old 06-15-2012
Senior Cruiser
sea_hunter's Avatar
Sika261 never hardens like 5200 or 4200 (adhesives) and remains flexible.
sea_hunter is offline
post #8 of 9 Old 06-15-2012
Fishin' from a Sailboat
I guess you are not near a Home Depot, Lowes or Walmart? All three carry 4200 here.
You are not talking about a major structural seal, stay away from 5200 as said above. If you go with silicone just make sure it is silicone ADHESIVE, not just regular silicone. Not just for the adhesive properties, I've just found it to last much longer. You'd be surprised how strong it is, I use it all the time in a pinch and bet it is just about as strong as 4200. Marine goop is probably a silicone adhesive but check the package. I use any "outdoor, waterproof" silicone adhesive, even below the waterline....never had it fail.
1980 San Juan 21 Mk II
Charlotte Harbor, FL
HarborRat is offline
post #9 of 9 Old 06-15-2012
Some degree of adhesion is necessary, otherwise water will be drawn in between the sealant and the deck by capillary action. That's why all the sealants recommended by manufacturers for chainplates and other deck hardware (LifeCaulk, LifeSeal, 3M 4200 and so on) are at least medium adhesion.
MarkSF is offline
Bedding one more time davidpm Gear & Maintenance 4 09-21-2011 02:47 PM
Dodger windows - cover or not cover? Gene T Gear & Maintenance 17 10-12-2010 03:50 PM
Which goop for bedding jephotog Gear & Maintenance 17 10-14-2009 10:06 AM
Re-bedding jib car track L124C Gear & Maintenance 12 11-25-2008 05:47 PM
Need help identifying chainplate cover... CLucas Gear & Maintenance 5 04-11-2007 10:34 PM
