Cleaning the Holding Tank - SailNet Community
post #1 of 12 Old 01-08-2004 Thread Starter
Can anyone give me tips on how to clean the inside of a holding tank that''s been neglected for ages? We bought this boat used and don''t want to take the time to replace the holding tank before our spring cruise. What''s the BEST stuff and procedure for cleaning it? Thanks!
LadyAV8R is offline
post #2 of 12 Old 01-09-2004
tm3
If it''s an odor problem I had a similar problem and after trying to eliminate the odor via the normal ways, changing hoses and using a variety of recommended additives I ended up getting a new holding tank.
One suggestion which I didn''t try was to fill the tank with water and add marbles then go sailing and let the marbles do their thing. Can''t say it will work but it''s worth a try.
tm3 is offline
post #3 of 12 Old 01-14-2004
tm3 --and after they "do their thing", how do you then get the marbles out?? Sounds like a great way to kill a macerator pump.
ross99 is offline
post #4 of 12 Old 01-15-2004
I had the same problem with a holding tank on my old boat. Here is what I found and did: First remove the holding tank from the boat if you can as this can get messy. Some of that supposedly "rapidly dissolving tissue" will probably still be in there. I used a wetdry vac to get that stuff out. I then filled the tank with a bleach-based solution and used a long-handled brush to scrub the sides of the tank. I had to do this several times to get it really clean. Let the bleach sit for a while while it does its thing. The marbles sound like an interesting idea. Probably just use a wet/dry vac to suck them out.
hamiam is offline
post #5 of 12 Old 01-18-2004
tm3
ross99....since I didn''t try that suggestion I didn''t need to worry about that but hamiam has a solution.
tm3 is offline
post #6 of 12 Old 10-21-2008
Cleaning Holding Tanks
DELETED BY CD
No ADvertising
AllPro is offline
post #7 of 12 Old 10-21-2008
never convicted
uh-oh--9-8-7-6-5-4-3-2.................
"Don't gain the world and lose your soul, Wisdom is better than silver and gold"----Bob Marley
100T Master NC
KODAD is offline
post #8 of 12 Old 10-21-2008
AllPro-
Please don't spam our forum with Advertising, which is clearly against the terms of service. There's also a post on full disclosure that you should probably read. You can find it here.
sailingdog is offline
post #9 of 12 Old 10-22-2008
HeadHoncho's Avatar
I don't have enough posts to be able to include a link, but do a Google search for "Happy Campers and Healthy Boaters" products. Good stuff, works great.
"Pump it, don't dump it."
HeadHoncho is offline
post #10 of 12 Old 10-22-2008
poopdeckpappy's Avatar
Healthy Boaters and Happy Campers
1955 Blanchard 51 Custom ( I got a woody )
1974 Ranger 33
Friends don't let friends do stupid things alone
poopdeckpappy is offline
Holding Tank Failure BillG501 Gear & Maintenance 3 09-23-2006 06:34 AM
Holding tank jeanneau 51 Myblueheaven Living Aboard 3 05-25-2006 05:06 PM
Holding or fuel tank jeanneau beneteau Myblueheaven Living Aboard 0 02-28-2005 10:35 AM
holding or fuel tank Jeanneau Beneteau Myblueheaven Cruising & Liveaboard Forum 0 02-28-2005 10:34 AM
removing orig water tank zeilfanaat Gear & Maintenance 6 04-12-2004 07:26 AM
