Can I apply epoxy filler over barrier coat? - SailNet Community
post #1 of 4 Old 06-15-2012 Thread Starter
patrscoe's Avatar
I recently had all blisters repaired, applied barrier coat and bottom paint but during transportation into the water, the bottom was scratched, leaving a long deep scratch in the hull. Not deep enough for any extensive fiberglass repair but pass the gelcoat.
It's been in the water for a while and I found this when I hauled out the sailboat to repair and upgrade two new through-hulls. Boatyard, which I am not at anymore, stated it was not there. I did not hit anything or develop this scratch.
Anyways, how it happen I guess is a unknown factor and I cannot do anything about it so I need to repair the scratch.
To the question, right or wrong, I don't want to strip the entire area and redo it.
Can I sand just the scratched area, apply epoxy filler or another similar filler or vinylester filler, touch up the barrier coat and apply two coats of bottom paint just in that area?
How perfect does the process has to be. I.E. if there are areas where the barrier coat is not completely removed but there are some filler over it?
Patrick
S2 11.0A 36'
Kinsale, Va
Tanzer 16'
Moseley, Va
patrscoe is offline
post #2 of 4 Old 06-15-2012
Re: Can I apply epoxy filler over barrier coat?
Scratched past gel coat to laminate ?
WDS123 is offline
post #3 of 4 Old 06-15-2012
ASA and PSIA Instructor
Use Interlux Watertite filler, Watertite Boat Filler | Interlux I believe its more impermeable than the barrier coat. When applying, fair carefully, as its a bear to sand. You can find it in the $$$ aisle.
sailingfool is online now
post #4 of 4 Old 06-15-2012
One of None
deniseO30's Avatar
barrier coat is epoxy. I had the same thing happen mixed up a batch and it's fine. I would sand it with course grit though.
My last project!
deniseO30 is offline
Epoxy Barrier coat stevemorrell Gear & Maintenance 7 01-15-2016 01:32 PM
Epoxy Barrier Coat over Gel Coat? lizardheadone Gear & Maintenance 4 01-14-2016 09:08 PM
2012 Oceanis 45 Epoxy barrier coat kellysails Beneteau 3 05-10-2012 05:19 PM
tar epoxy barrier coat on fiberglass erpwyeth Gear & Maintenance 2 06-13-2010 07:30 PM
EPOXY BARRIER COAT DILEMMA, help ..... Freesail99 Gear & Maintenance 5 06-07-2010 07:14 AM
