head problem - SailNet Community
Blogs
Old 01-09-2004
ahewi9426 is on a distinguished road
head problem
My 30'' Morgan has an added water tank and as a result I had to install the holding tank to one side and the inlet is about 6" higher than the outlet from the head and on the starboard side. The head is on the left. I was going to run the hose from the head, up the bulkhead about 18". Then back down to the tank inlet. Will there be waste in the hose, and will it run back into the head. Is there a way to solve this.
Old 01-22-2004
KenD is on a distinguished road
head problem
Go to boat-us or west marine they have FREE sheets on various subjects such as head installations. you don''t mention a y valve or vented loop you will need one
Control Head fix for Merriman Steering System tdp Gear & Maintenance 1 06-09-2011 04:00 PM
What''s the best toilet (head) and... Myblueheaven Cruising & Liveaboard Forum 2 10-04-2003 10:52 AM
Head installation Irwin32 Gear & Maintenance 4 03-20-2003 01:23 PM
Rudder head corrosion aflanigan Gear & Maintenance 3 01-27-2003 02:01 AM
Head Problems bootsy1962 General Discussion (sailing related) 3 02-19-2002 08:26 PM
SEO by vBSEO 3.6.0
(c) Sailnet 2000-2006
