Air dry gel coat? - SailNet Community
post #1 of 6 Old 06-18-2012 Thread Starter
bigdogandy's Avatar
Dock
Air dry gel coat?
I have a few stress cracks and dings in the gelcoat on the cabintop and cockpit that I've been contemplating how to fix. The balance of the gelcoat is tired and chalky but I think I could buff it back to reasonably close to its original glory following Mainesail's compound and waxing tips.........I do want to fix the dings but I'd really rather not paint the topsides if I can avoid it.
One of the guys at the marina has done some nice work on his old Islander and he suggested using West system to repair the bad spots and using an air dry gelcoat for the finish.....he says in his experience not having to cover the gelcoat patches with plastic while it cures makes the process a bit simpler.
I'm curious if anyone else in the group has any experience with the air dry gel coat and would be willing to share their opinions on it?
Andy
Key Largo
S/V Everlasting Moon
1981 Endeavour 32
Be joyful though you have considered all the facts.
- Wendell Berry
bigdogandy is offline
post #2 of 6 Old 06-18-2012
RichH's Avatar
Re: Air dry gel coat?
Why go to all the bother?
Just use polyvinyl alcohol (PVA) and spray it on the surface when done for a 'surface cure' of the gelcoat. PVA is also known as 'parting fluid' or 'mold release' and causes a surface cure of the gel.
Use a PreVal 'aerosol type' self-contained sprayer that you 'load' any (pre-filtered) fluid you want, including diluted down gelcoat. Just mist on the PVA when you have the correct thickness of gel for a 'good cure' of the gel. Dont mess around with non-air inhibited gels as they are a royal PITA to work with; rather use/spray-on PVA and take your time in working up the preparatory finish/depth you want ... then spray on PVA to cure it.
You really have to flat sand and polish out gelcoat repairs no matter how you apply it. PVA overcoats are 'the' way to go here. Besides, once the gel is cured the PVA is water soluble.
Polyvinyl Alcohol
Preval Sprayer
RichH is offline
post #3 of 6 Old 06-18-2012
Sundown Sailing
Sundownsailing's Avatar
Check out Duratec. It is a additive for spray and allows for "air dry"
Duratec Clear Hi-Gloss Gel Coat Additive : Duratec : Boat Building : Repair : Mold Buidling
Cheers
Clay and Kim
s/v Sundown
Hans Christian 33T
Sundownsailing is offline
post #4 of 6 Old 06-19-2012 Thread Starter
bigdogandy's Avatar
Dock
Thanks for the tips, guys. I think I'll try the PVA first on a small ding in the anchor locker and see what happens!
Andy
Key Largo
1981 Endeavour 32
- Wendell Berry
post #5 of 6 Old 06-19-2012
TQA
Bombay Explorer 44
TQA's Avatar
West System web site has good guides on how to and projects eg.
CLICKY
TQA is offline
post #6 of 6 Old 06-19-2012
Learning the HARD way...
eherlihy's Avatar
Jamestown distribuitors has Gel coat "containing wax" that you mix up and apply like paint. the stuff stinks, but seems to work well on my boat. Also, it was the only way that I could match the cream color of my O'day's hull.
Look here;Colored Gelcoat They have even posted a video of how to use.
eherlihy is online now
Epoxy Barrier Coat over Gel Coat? lizardheadone Gear & Maintenance 4 01-14-2016 09:08 PM
Bottom paint over Gel Coat without Barrier Coat? WagTheDog Gear & Maintenance 17 07-15-2012 07:33 AM
Gel Coat weephee General Discussion (sailing related) 11 03-22-2010 01:42 AM
Gel-coat pro in the NE SteveInMD Gear & Maintenance 0 05-27-2009 12:49 PM
gel coat dm567 Gear & Maintenance 15 01-02-2007 11:55 AM
