Like Tree1Likes
  #11
Old 09-04-2012
bigdogandy's Avatar
bigdogandy is on a distinguished road
Re: Port windows replacement
I bought a set of the NewFound Metals tri-matrix ports a while back that I will be installing this fall. They are much higher quality than the old Becksons, and the tri-matrix ports were about half the cost of similar sized stainless or bronze. If you plan to keep the boat for a while they are a great investment. I agree that you need to make sure you have uniformly solid surfaces inside and out and use the butyl tape for bedding.
bvander66 likes this.
Andy
Merritt Island
1981 Endeavour 32
"At sea, I learned how little a person needs, not how much." Robin Lee Graham
  #12
Old 09-07-2012
Romario is on a distinguished road
Ordered 4 beckson 714. Do I need anything besides butyl tape? Do the ports come with all the screws that I need to install it?
  #13
Old 09-08-2012
Irrationally Exuberant
arf145 is on a distinguished road
Beckson highly recommends a good construction silicone--Dow Corning 795 I believe. I know I know, silicone is the devil. I use butyl for everything, but I used the silicone Beckson recommends when I installed a couple of their ports. Wasn't sure that the butyl would be compatible.
Tom K
2000 Beneteau 331
1987 Pearson 28-2
Northern Chesapeake Bay
  #14
Old 12-07-2012
Ocean88 is on a distinguished road
I have a Morgan Classic 1988 and one of the portllights(Lense) just cracked. How do I find out what model it is? Lewmar said I had to send them a picture. Any other technique?
  #15
Old 12-07-2012
LinekinBayCD is on a distinguished road
I'll second the New Found Metal Ports of any type. Replaced my old plastic ports with the New Found Metal bronze ports. Very well made.
  #16
Old 12-08-2012
olson34 is on a distinguished road
Lightbulb Re: Port windows replacement
Speaking of replacement opeining ports...
This line of ports has been around for decades. I have heard good reviews, but have never installed any.
You might want to check on the cut-out sizing.
Fuller Brush Marine
  #17
Old 12-18-2012
Brian_A's Avatar
Marine Manufacturer
Brian_A is on a distinguished road
Hi Everyone,
Brian Atkins, Atkins & Hoyle Ltd. We are Marine Hatch and Port Manufacturers.
There are a few makers of hatches and ports left in the world today, several mentioned in this post will 'get the job done'. From our experience, plastic ports just don't seem to last as long as metal ones. We have also found that extruded hatches and ports tend to be much weaker then cast, and are not as easy to repair when the time comes due. On many boats, especially those in salt water, lower quality metal hatches and ports will rust over time.
In terms of sealing around the frame of your hatches or ports, we recommend Silicone as well. We used to use Butyl Tape, but it can be very messy, and doesn't seem to provide as good of a seal. Often just a small bead of Silicone around the edge of the frame, and a little around each screw hole, will work great as a sealant. Fresh Silicone often 'squeezes' out once you start tightening the frame to the boat, we often recommend taping off around the frame, and allow the glue to 'tack' up before trying to clean up - otherwise you may just spread wet silicone everywhere else.
There are stronger adhesives available, but we find the silicone seal lasts for more then 20 years before needing to be re-sealed. This is often perfect timing to have them re-furbished and put back on the boat with new sealant.
If you are still having issues finding something of high quality and that fits into your pre-existing cutout, feel free to PM me and I will help direct you as best we can. Thanks.
Brian Atkins
Quality Marine Hardware, Manufacturer
You may post attachments
You may edit your posts
Replacement portlights / windows Relic Seafarer 4 12-07-2012 06:52 PM
Port Hole Replacement Harborless Gear & Maintenance 4 09-14-2011 11:21 AM
replacement windows Kiltmadoc General Discussion (sailing related) 2 10-26-2010 04:50 PM
C&C 32 Port Light Replacement scraph C & C 1 05-14-2010 09:03 AM
Opening port Replacement AES1691 Morgan 1 07-16-2008 11:56 AM
SEO by vBSEO 3.6.1
