snatch block on cars for jib sheets? - SailNet Community
 5Likes
post #1 of 15 Old 06-19-2012 Thread Starter
Sootydan's Avatar
Question snatch block on cars for jib sheets?
[B][/BOk I have the Harken roller furler and jib all set up, can I use or (what should I use) snatch blocks on the jib cars that are installed on my boat. It's a Cal 2-30 The jib cars are just loops , no pulley? Here's a pic of a similar jib car .I know I need a rig to keep the jib sheets down closer to the boat.
Sootydan is offline
post #2 of 15 Old 06-19-2012
Junior member, rest old
msmith10's Avatar
Re: snatch block on cars for jib sheets?
You can use snatch blocks but they're pretty expensive for that purpose. Just use a regular block with swivel becket attached to the U in the track car. Save the snatch blocks for temporary things when they're really helpful.
Faster and jackdale like this.
Mark Smith
1977 C&C 30 Mk 1 hailing from Port Clinton, Ohio
msmith10 is offline
post #3 of 15 Old 06-19-2012
Snatch blocks also tend to be heavy and will bang around in the light stuff, making annoying noises and not doing your gelcoat any good.
Regular blocks shackled in with 'stand up springs' will be a much better setup, improved only by the wide roller-style jib leads like these:
chef2sail and SchockT like this.
Faster is offline
post #4 of 15 Old 06-19-2012 Thread Starter
Sootydan's Avatar
Thanks for the help!
Sootydan is offline
post #5 of 15 Old 06-19-2012
Cruiser2B's Avatar
i use snatch blocks, i have 2 sets of cars on my jib tracks, allows me to use either set depending on head sail. I have 2 sets of cars because i have a moveable cleat inbetween the 2 for spring lines at the dock. Snatch blocks work well for me.
My two lovely ladies!!
USCG 100T Near Coast Master with 100T Inland Sail Endorsement
Cruiser2B is offline
post #6 of 15 Old 06-19-2012
SchockT's Avatar
If you can, you should get proper fairleads like the ones Faster showed you. They are FAR better than having blocks flopping around on deck. The sheet will run much smoother through it, particularly when the sail is flogging and they are also a whole lot easier to adjust when the sail is up.
chef2sail likes this.
1979 Santana 30 Tall Rig
Hull#101
SchockT is offline
post #7 of 15 Old 06-20-2012
Senior Cruiser
sea_hunter's Avatar
I've used snatch blocks (different sizes) for over 40 years and they never "banged". There's all kinds of pulleys and track cars today but a snatch block is reliable, quick to rig and is multi-purpose. On heavy cruisers it is almost always the best option.
sea_hunter is offline
post #8 of 15 Old 06-20-2012
The problem with snatch blocks is they are inherently weaker and more expensive than jib cars. And not by a little bit either, the differences can be pretty significant.
For instance, the harken mid-range geneoa lead is $181, as compared to a comparable working load snatch block at $357.
For your boat you probably don't need to go that big, and could get away with a small boat jib car at $133. Harken does not make a snatch block in that size though, so you are stuck with the $357 one instead.
Greg
Stumble is offline
post #9 of 15 Old 06-20-2012 Thread Starter
Sootydan's Avatar
This is what I have at the moment, haven't changed anything yet. The snatch blocks came with the boat so I tried them, there's a bungee to keep it from flopping I assume the original owner set up. Taking all the good info you guys gave me and going from there
Sootydan is offline
post #10 of 15 Old 06-20-2012
SchockT's Avatar
Wow, your genoa sheets pretty far outboard! You don't have any inboard tracks? That looks more like a barber haul or spinnaker guy location!
Hull#101
SchockT is offline
Snatch block for misc. use? n0w0rries Gear & Maintenance 15 02-23-2010 07:52 PM
Using a snatch block for a Bahamian Moor labatt General Discussion (sailing related) 12 04-09-2009 06:22 PM
Double Snatch Block? danielgoldberg Gear & Maintenance 13 04-07-2008 10:40 AM
Snatch block placement on S2 8.0 overholtzer S2 2 09-11-2007 06:46 PM
Equivalent of snatch block, but for clutch or cam? labatt Gear & Maintenance 14 04-10-2007 04:18 PM
