Furler hard to unfurl/furl on genoa - Page 2 - SailNet Community
post #11 of 15 Old 06-20-2012
tommays's Avatar
Re: Furler hard to unfurl/furl on genoa
Profurl Bearings
looks like my profurl which have sealed metal beraings
1970 Cal 29 Sea Fever
1981 J24 Tangent 2930
Tommays
Northport NY
tommays is offline
post #12 of 15 Old 06-20-2012
RichH's Avatar
Loosen the halyard and 'spin' the drum by hand .... if spins freely its not the bearings in the lower unit.
Drop the sail and do the same with upper swivel .... if spins freely its not the bearings in the 'top swivel' unit.
THEN ... raise the sail and look to see where the top swivel is - it should (usually) be within 1 - 2" of the VERY TOP of the foil. You can do the same thing by raising the sail all-the-way-up with its tack disconnected .... when the disconnected tack sail is raised there should only be a gap or ~2" between the sails tack and the furler drum connection.
If the sail's luff is too short for the foil which leaves the upper top swivel at GREATER than 1 - 2" below the TOP of the foil, then make up a pendent of rope, etc. to make up the distance (your choice if the pendent attaches to the head or tack of the sail) .... so that the top-swivel is near that 1-2" from the top of the foil. This will create the correct 'lead angle' for the top swivel - the angle that the halyard makes from its sheave exit to the top swivel connection. Your furler manual has this exact angle - called 'lead angle'.
If the lead angle is LESS than whats specified the halyard will invariably 'wrap' and bind the top swivel as you attempt to furl. You can usually see with binoculars the halyard 'toggling' around the top swivel when the lead angle is 'wrong', the halyard is now interfering ('toggling' or 'attempting to wrap around the swivel') with the top swivel causing the apparent 'jam'.
If the pendent doesnt solve your problem ... then you need a 'diverter block' installed at near the top of the mast so that the 'lead angle' is correct.
Rx: If its not the bearings, then assay the halyard 'lead angle' at the top swivel.
RichH is offline
post #13 of 15 Old 06-20-2012
A client, who worked for a rigger, spent a lot of time getting rid of the halyard swivel, replacing it with a block on the side of the extrusion, eliminating that problem.
Brent Swain is offline
post #14 of 15 Old 06-20-2012
KNOT KNOWN
Capt.aaron's Avatar
I belive this is the case. As a rigger in Miami I installed a lot of "diverter bolcks" on boats to change the angle of the Hallyard to the swivel. That "hump" sound is the top extrusion coming free of the hallyard.
" Some are boat wise and some are other wise"
Capt.aaron is offline
post #15 of 15 Old 06-22-2012
CaptainWabamun's Avatar
Rosmario - was expereincing same issue with my new-to-me Catalina 27 during my first weeks of sailing with it last summer. Problem was halyard wrap at the top of the furler. At least two remedies - I tried first last summe without much success which was adding a modified piece of cable to get some more distance between the top furler drum and the halyard. Eliminated some but not all occasions of the problem. Going up mast tomorrow to try second remedy which is to add a halyard organizer onto the mast to achieve a recomended 10 degree angle and more controlled distance between my halyard, the forestay and the furler drum.
..with such short seasons for sailing up north I'll be setting mast climbing record I am sure ;')
Barry
CaptainWabamun is offline
How to reef/furl a genoa/jib Ronbye General Discussion (sailing related) 10 11-24-2015 12:45 AM
Acrobatic feats on sailboat to unfurl on Olympic Peninsula - Peninsula Daily NewsReader News Feeds 0 08-19-2011 07:20 AM
Gennaker Set, before or after genoa furl? clancy11 Seamanship & Navigation 11 06-02-2011 08:35 AM
Old Roller Furler (a.k.a. "To Furl, or Not To Furl...") supergrade Gear & Maintenance 34 12-24-2008 12:36 PM
Furler Won't Unfurl CatalinaSteve Gear & Maintenance 6 05-21-2007 12:01 AM
