Need Exhust Manifold for Volvo MD6A - SailNet Community
post #1 of 11 Old 06-20-2012 Thread Starter
Red face Need Exhust Manifold for Volvo MD6A
Hello;
New to Sail Net and never posted before. Hope I do it right.
I have a Volvo Penta MD6A and have a crack in the exhaust manifold (they call it an exhaust pipe in the engine manual.
Every where I look on line I can't find one. Any thoughts. Also been thinking about repowering (8,000 lbs displacement), but unsure the direction to go in to save $$$$. Can't find anything on line, any thoughts?
Thanks
David - sailingforjoy
SailingforJoy is offline
post #2 of 11 Old 06-20-2012
Re: Need Exhust Manifold for Volvo MD6A
Try these guys first.
Volvo Penta, Mercruiser and more - Marine Parts Express - engines, outdrives, propellers
If not give these folks a shout.
Volvo Penta Parts & Accessories Marine Diesel & Gas Engine | Power Products Systems, LLC
I'm not happy unless I'm complaining about something.
I'm having a very good day!
misfits is offline
post #3 of 11 Old 06-20-2012 Thread Starter
Thanks misfits
I'll give them a try
dr-sailingforjoy
post #4 of 11 Old 06-20-2012
SailingforJoy,
Forgot to add this to the previous response...
I've heard that the exhuast mainfolds for these motors are very expensive. I believe they are made from cast-iron so depending on where it's cracked, you may be able to have a good welder fix it for you.
misfits is offline
post #5 of 11 Old 06-20-2012 Thread Starter
Thanks misfits
I checked out both sites. Nither had the part. but was able to download a operators manual!
My thoughts the same on the welding - I do have a man that should be able to do it.
Thanks again
sailingforjoy
dr
post #6 of 11 Old 06-20-2012
Add Content
GaryHLucas is offline
post #7 of 11 Old 06-20-2012
SchockT's Avatar
Are you sure it is not the exhaust elbow? (it looks more like a pipe.) It is the piece at the back of the engine that the exhaust hose connects to. It is a common part to rust out and is readily available for around $150. I just replaced mine and the local dealer had it in stock.
1979 Santana 30 Tall Rig
Hull#101
SchockT is offline
post #8 of 11 Old 06-20-2012
I would suggest giving Torrensens marine a call. They deal in a lot of parts for older Volvo engines and they have a lot of parts not listed on the website.
klem is offline
post #9 of 11 Old 06-20-2012 Thread Starter
Thanks - SchockT and Klem, for responding back.
SchockT; it is the water cooled exhaust manifold, I used the term exhaust pipe as that is a name that Volvo Penta uses in their manual also. My elbow is in great shape.
Klem; thanks for the lead I'll contact Torrensens.
Happy sailing
sailingforjoy -dr
post #10 of 11 Old 06-27-2012 Thread Starter
Well it's back to the drawing board! I know a couple of good welders and fabracators here in my area, and I showed them some photos of the crack in the manifold and based on what they saw felt that they could weild it. But after getting it off the crack was much more extensive than first thought. It is cracked on the bottom also, half the length of the manifold. So welding is not an opption any longer. So here's looking for a manifold.
sailingforjoy
Tags
exhaust manifold , repower , volvo penta md6a
md6a rev meter santana30RI Gear & Maintenance 0 02-13-2012 08:31 PM
Cruise speed with Volvo MD6A diesel talbot Gear & Maintenance 7 10-26-2009 10:07 PM
MD6A Woes scurvy Gear & Maintenance 15 07-29-2007 05:55 PM
Volvo MD-11C Exhaust manifold flydude3 Gear & Maintenance 1 04-14-2005 01:06 AM
Volvo intake valves for MD6A not avaiable from Volvo Larrys Pal Gear & Maintenance 5 03-27-2002 05:58 AM
