destroyed impeller - Page 3 - SailNet Community
 5Likes
post #21 of 23 Old 07-30-2012 Thread Starter
Re: destroyed impeller
Pearsonistic,
Sorry, I cannot help as I am not familiar with the Atomic 4, you might start another thread and ask the question as people with Atomics may not be monitoring this thread as they know it is about a Yanmar.
CapnRon47 is offline
post #22 of 23 Old 08-01-2012
Old as Dirt!
svHyLyte's Avatar
Originally Posted by CapnRon47 View Post
When I got home I took apart the 'old' pump and found 4 of the six impeller blades still in the pump but un-attached. I am assuming the other two are working their way up into the heat exchanger and will eventually plug the mixing elbow. So I plan to back flush the heat exchanger to see if I can clean it out. Any thoughts, comments or suggestions on this procedure. I had not planned to open the end face plate of the heat exchanger, just flush it using the output and input hose connections. But I could be convinced otherwise.
thanks,
Ron--
Unless you've already made this effort and my comments are redundant, simply back washing with a garden hose to the output side of the heat exchanger and a hose to a bucket on the input side should wash out the "bits 'n pieces". If they do not appear, check the hose between your raw water pump and the heat exchanger as they may be lodged there.
Once you've recovered the debris, to clean out the tube bundle itself, you can use a cleaning agent like RydLyme or Barnacle Buster in a bucket with a small inexpensive submersible bilge pump ($29.00 at WM). A hose from the pump is connected to the discharge side of the heat exchanger and the hose from the input side is led back to the bucket. You can power the pump with some jumpers led back to your house bank. By recirculating a solution of RydLyme in this manner, you will remove most of the scale that may/will have built up in your tube bundle. If you are worried about debris being recirculated, a couple of wraps of cheese-cloth around the base of the submersible pump makes a pretty efficient filter without obstructing flow. You can test the efficacy of the solution by dipping a shell in the bucket. As long as it "fizzes" the stuffs still good. Four to six hours should be more than long enough with RydLyme although there is a table of recirculation times on the company's web-site.
In future, hang your ignition key on the handle of your raw water through hull.
FWIW...
svHyLyte is offline
post #23 of 23 Old 08-01-2012 Thread Starter
Scott,
Thanks, I did the back flush thing and even better than checking the input hoses, I replaced them with new. I really did not find any pieces, so they must have been ground up (there was a lot of 'black dust' in the intake water pump). She seems to be good as the Yanmar starts right up and runs just fine. The oil and the coolant look good too. The scale buildup did not look too bad so I put that off until another day. We have a Moonlight cruise coming up this week and I wanted to get everything back together and tested as soon as possible. So far so good.
thanks,
Rhode Island YC Destroyed by Fire SOUNDBOUNDER General Discussion (sailing related) 5 01-21-2011 03:58 PM
Boats Destroyed in Marina Roof Collapses TakeFive General Discussion (sailing related) 4 02-28-2010 11:38 AM
Engine destroyed by anti-siphon valve jimfortuna Gear & Maintenance 19 01-14-2008 08:50 AM
Destroyed by fire YC seeking Burgee donations via Fordham University NewsReader Mass Bay Sailors 0 10-24-2006 09:15 AM
Hammond, Indiana, Marina effectively destroyed jdkirkk General Discussion (sailing related) 4 03-01-2006 10:43 AM
