Temporary adhesive in bilge - SailNet Community
 1Likes
  • 1 Post By CorvetteGuy
post #1 of 5 Old 06-22-2012 Thread Starter
I've just bought an old boat without an auto bilge pump. I would like to install it immediately, but the bilge is wet and likely won't be dry until next spring. So epoxy would seem to be out. Is there an adhesive I could use temporarily which would tolerate a wet surface, and hold the bilge pump in place temporarily? Of course I also want to be able to remove it and epoxy the pump in next spring.
I've thought about 3m 4200, but don't know either about its strength, or the moisture factor. Would it work? Other ideas? Thanks!
waterscholar is offline
post #2 of 5 Old 06-22-2012
Re: Temporary adhesive in bilge
My bilge pump is fastened to a metal rod with a handle at the top. The handle is fastened to a bracket at the top of the bilge space with cable ties. Thus the bilge pump is held in place, but no adhesive is required and the pump may be easily removed for service / replacement.
MarkSF is offline
post #3 of 5 Old 06-22-2012
jsaronson's Avatar
Rather than a metal rod I would use a piece of 1/2 inch PVC to avoid corrosion. I wouldn't permanently mount the pump in the bilge.
jsaronson is offline
post #4 of 5 Old 06-22-2012
Otter
DivingOtter's Avatar
Buy some SplashZone.
DivingOtter is offline
post #5 of 5 Old 06-22-2012
72 C&C Corvette
CorvetteGuy's Avatar
aqua mend is a 2 part epoxy putty when mixed together by hand will cure under water just a little dab will do ya. but dont permantly mount it in the bildge as one day you will need to replace it. Mine fits in the bildge with a friction fit, wedge it in place, and there is always some water in the bildge, float switch sits about 5" from the bottom. If there is no water in the bildge then the boat is too new.
Somekindofaviking likes this.
CorvetteGuy is offline
Just temporary, but it should hold 71Irwin32 Gear & Maintenance 35 01-13-2010 12:55 AM
Using a temporary mooring PBzeer Seamanship & Navigation 27 04-25-2007 07:25 PM
Temporary slip available in Key Biscayne dnseal Cruising & Liveaboard Forum 4 12-14-2006 01:21 PM
Temporary Moorings Dan Dickison Gear and Maintenance Articles 0 07-21-2002 08:00 PM
temporary jib set-up sailorman_10 Gear & Maintenance 3 03-29-2002 03:34 AM
