fiberglass textured deck repair questions - Page 2 - SailNet Community
post #11 of 13 Old 06-24-2012
72 C&C Corvette
CorvetteGuy's Avatar
Re: fiberglass textured deck repair questions
I refinished our deck with kiwi grip and went right over the original diomand nonskid. Applied thick enough it covered the old, very happy with the results
CorvetteGuy is offline
post #12 of 13 Old 06-24-2012
fiberglass1's Avatar
If you want to preserve the original diamond pattern you can purchase any production pattern from Gibco Mold Flex. They manufacture fiberglass panels with the pattern molded in gel coat and you just cut to shape and glue them down. There is a little finish work to do on the cut edges but no big deal.
fiberglass1 is offline
post #13 of 13 Old 06-24-2012
Seņor Member
PorFin's Avatar
If you REALLY want to keep it more or less original, you can do that too.
The diamond texture is nothing more than gelcoat, and can be repaired. Here's a
on how to do it.
The Gibco mold can be a little expensive -- I've made my own for small repairs using latex available at crafts stores (like Michaels.) You just find a spot on your nonskid that is in good shape and add multiple layers of latex to build it up into a usable thickness.
PorFin is offline
Seeking opinions for deck and hull-deck joint repair gregor1234 Gear & Maintenance 8 04-25-2012 11:10 PM
deck and fiberglass repair stm Gear & Maintenance 0 11-09-2010 05:45 PM
serious fiberglass repair- help hertfordnc Sailboat Design and Construction 11 07-09-2009 11:21 PM
B&K Fiberglass Repair brak Gear & Maintenance 0 05-16-2007 02:48 PM
First Fiberglass Repair SailNet Gear and Maintenance Articles 0 09-01-2001 08:00 PM
