stripping deck paint--painful! - Page 4 - SailNet Community
 1Likes
post #31 of 36 Old 07-08-2012 Thread Starter
muskoka.sailor's Avatar
Eric, did you prime before applying deck paint, or just slapped it on after sanding? In thinking just paint a couple coats and be happy with that, but just thot I'd ask to be sure.
muskoka.sailor is offline
post #32 of 36 Old 07-19-2012
midlife crisis member
AllThumbs's Avatar
Re: stripping deck paint--painful!
I didn't prime it first.
AllThumbs is offline
post #33 of 36 Old 07-20-2012
bljones's Avatar
I did.
It's 5 o'clock somewhere:
bljones is offline
post #34 of 36 Old 05-08-2013
asdf38's Avatar
Originally Posted by mbsl98 View Post
I have become a big fan of using AquaStrip remover on fiberglass and wood. Paint it on and let it sit, warm weather is better. Possibly paint on a second coat. Then lift the old junk away. Can get expensive, and messy, but easy and the offset of saved labor and time seems to be a fair trade. Once the paint is gone, you can sand to prep for new paint, change non-skid, etc as desired.
Here it is in action stripping 25 years of Cetol over original varnish for lots of teak on my 22' Marshall Cat, and also did great removing years of Penetrol build-up left from the prior owner's use of that stuff to keep decks looking good,. (It's OK until you stop, and then it is black and peeling.)
So I took home my engine panel (cockpit floor) for refinishing. It looks particularly bad and I want it to be a test run for possible future deck painting.
It's mostly painted non-skid (of unknown type) So first I tried the heat gun and scraper with some success. It was able to cleanly lift off chunks of the non-skid right down to the old gelcoat, although it was slow going and required a lot of heat.
Next I tried Aqua Strip. On the edges which aren't non-skid this worked pretty well, however after two coats (4 hours, 20 hours) it hasn't penetrated the non-skid. And worse, now the nonskid can't be removed by scraping because it doesn't hold together.
As another test I attacked it with the random orbital sander with 80 grit. It resisted this pretty damn well. 10 minutes had produced almost no results, far worse than scraping.
Any suggestions? It appears the non-skid was best removed by the heat gun and scraping. Although I'm still hoping another coat or two of Aqua Strip will get down to the gelcoat.
So far this effort on roughly 4 square feet doesn't bode well for future painting of the entire deck...
asdf38 is offline
post #35 of 36 Old 05-08-2013
Have a go and DIY .....
Originally Posted by muskoka.sailor View Post
hi all,
I've been working on my DS20 this season, and I'm at the point of prepping for deck paint. I have all hardware off and have a clean surface to work with. I've been using 80 grit on an orbital sander, planning to get to hard to reach areas by hand when I've finished flatter surfaces. I'm finding this to be quite a chore, and I can imagine it's going to get worse once I have to switch over to manual method. The current deck paint, including non-skid areas is a water based acrylic from who-knows-what-store, and that seems to come off with a generous rubbing with acetone. Should I just strip the deck with acetone and then apply the new paint? Or should I carry on with my maddening sanding? Somebody help!
I used a hot air paint stripper on mine then a very light sand and the decks were clear and clean...
macwester26 is offline
post #36 of 36 Old 05-08-2013
Senior Moment Member
SloopJonB's Avatar
80 grit is way too fine for stripping and coarse prep work. Start with 40 and you'll make some headway.
For no gloss finishes like bottom paint, non-skid paint and so forth, I stop at 80 grit on an orbital.
SloopJonB is online now
Stripping the bottom paint McSwiggin General Discussion (sailing related) 21 06-03-2012 10:35 PM
stripping paint bluewhale Gear & Maintenance 3 11-09-2008 12:23 PM
Stripping Bottom Paint SailinJay Gear & Maintenance 12 11-05-2006 12:21 AM
