stripping deck paint--painful! - SailNet Community
 1Likes
post #1 of 36 Old 06-24-2012 Thread Starter
muskoka.sailor's Avatar
hi all,
I've been working on my DS20 this season, and I'm at the point of prepping for deck paint. I have all hardware off and have a clean surface to work with. I've been using 80 grit on an orbital sander, planning to get to hard to reach areas by hand when I've finished flatter surfaces. I'm finding this to be quite a chore, and I can imagine it's going to get worse once I have to switch over to manual method. The current deck paint, including non-skid areas is a water based acrylic from who-knows-what-store, and that seems to come off with a generous rubbing with acetone. Should I just strip the deck with acetone and then apply the new paint? Or should I carry on with my maddening sanding? Somebody help!
muskoka.sailor is offline
post #2 of 36 Old 06-24-2012
Senior Moment Member
SloopJonB's Avatar
Re: stripping deck paint--painful!
Originally Posted by muskoka.sailor View Post
hi all,
Why not use proper stripper that's safe for fiberglass?
SloopJonB is offline
post #3 of 36 Old 06-24-2012 Thread Starter
Isn't acetone ok for use on fiberglass? Casey recommends it for degreasing and whatnot before painting.
post #4 of 36 Old 06-24-2012 Thread Starter
Should I be using something like interlux 202?
post #5 of 36 Old 06-24-2012
asdf38's Avatar
Sorry, can't help. Just wanted to comment that I read these deck re-painting threads with trepidation as it's a task I may eventually face on my painted deck. I wish I better understood what circumstances cause so many owners to paint their decks and why they think it's a good thing to do. In my mind you should only paint a deck (for the fist time) if you're rich and you plan to have it done professionally and then re-done every 5 years and you have no problem with the exorbitant cost. Otherwise if you want your boat to look nice, even if it has a mediocre gelcoat you're better off leaving it as-is instead of guaranteeing that you'll have chipping dirty paint in 5 years.
asdf38 is offline
post #6 of 36 Old 06-24-2012 Thread Starter
Asdf38,
I certainly agree with you. The only problem is the guys I bought the boat from used water based acrylic to paint the deck and cockpit, and it looks terrible! I'm doing myself and whoever the future owner of this boat is a favor by sanding and repainting. It's just a real drag, even though I only have 20 feet of boat to take care of.
post #7 of 36 Old 06-24-2012
SloopJonB's Avatar
Acetone acts as a thinner for polyester resin. A wipe down as a pre-cleaner is different than using it as a paint stripper on glass - might be a bit too aggressive.
It is also VERY volatile - it evaporates before you can do much with it and it's toxic.
I'd rather use a stripper in your situation. If you have water based paint, you can use a water based stripper that you can simply hose off.
post #8 of 36 Old 06-26-2012 Thread Starter
Thanks Jon! Would a stripper from the local hardware store work ok? Would you know of any that would be of help? I'm pretty new at all this, so this might seem elementary....
post #9 of 36 Old 06-26-2012
SloopJonB's Avatar
Just make sure it is "safe for use on fiberglass". I'd avoid buying it from "Marine" sources and look at paint/chemical suppliers. If the staff can't help, check the manufacturers websites for the info. Fiberglass suppliers might have it or know of good ones. Corvette shops as well.
Remember to round the corners of all your scrapers as well!
Recent issues of the British mag "Practical Boat Owner" have had articles on this very thing - they are restoring a a 20-ish footer that looks like yours sounds.
post #10 of 36 Old 06-26-2012
mikehoyt's Avatar
We refinished the deck on our previous boat. We also had no idea what paint was used but I suspect was also acrylic, enamel or similar. It also like yours looked terrible and was failing - and the paint job was less than five years old.
I sanded using ROS as you are with a contour sander for hard to get areas. I did not remove all of the old paint but likely most of it with the sanding. As we were using a two part system a proper two part primer is mandatory as the new paint will destroy the old paint under it if not primed. In your mind know that no matter how hard you try there will be some residue or more of the old paint so this is imprortant. Wiping down with Interlux 202 solvent wash is also a very good idea.
The paint used for refinish was Interlux Interthane Plus (now called Perfection). I did all the prep work and had a pro spray the paint. The end result looked fabulous and held up very well for the remaining years we had the boat
Hope this helps. Refinishing the deck is a very big job.
Mike
Mike
mikehoyt is offline
Stripping the bottom paint McSwiggin General Discussion (sailing related) 21 06-03-2012 10:35 PM
stripping paint bluewhale Gear & Maintenance 3 11-09-2008 12:23 PM
Stripping Bottom Paint SailinJay Gear & Maintenance 12 11-05-2006 12:21 AM
