What is wrong with my outboard? - SailNet Community
 1Likes
  • 1 Post By mdbee
post #1 of 10 Old 06-24-2012 Thread Starter
O'Day 272 - "Pana-Sea-A"
So I went to start my 9.9 JP Merc today and when I was priming the outboard, I noticed gas dripping into the water. I opened it up and found a small hose that seemed to be disconnected, but I could not find a place where the connection would be. Any idea at all what could be wrong? The engine worked perfectly the day before.
Mjfossler is offline
post #2 of 10 Old 06-24-2012
dnf777's Avatar
Re: What is wrong with my outboard?
Had a 7.5, but I'll try to help. Did you try squeezing the primer with the cover off and locate the leak? Fuel lines should go somewhere, so I suspect the line is disconnected from the inside of the line fitting. Can you see a nipple near the end of the line? Also, some motors will have the filter in-line, and it may have become disconnected. Shouldn't happen, so that goes for a lot of things.
Good luck with it.
dnf777 is offline
post #3 of 10 Old 06-24-2012
Large Member
Another thought. That may be a vent line or an overflow line. It may suppose to be left open. Your carb float may be sticking and fuel is simply overflowing. Try tapping on the carb float bowl gently.
LooseDiamond likes this.
mdbee is offline
post #4 of 10 Old 06-24-2012
KNOT KNOWN
Capt.aaron's Avatar
Almost positive that goes to the fuel pump. Look again, I bet there is a black plastic nipple missing a hose. They usually use a spring clamp to hold the hose on and this is insufficiant. I hate to say it but the main problem you have is it's a Mercury.
" Some are boat wise and some are other wise"
Capt.aaron is offline
post #5 of 10 Old 06-24-2012
Large Member
It was running the day before. Assuming that no one jacked with it, hoses rarely disconnect themselves, even if it didn't have a clip on it.
mdbee is offline
post #6 of 10 Old 06-24-2012 Thread Starter
A detail I forgot to mention- the hose in question is cut at an angle. Capt. A , I looked and looked but could not find any nipple in the area.
post #7 of 10 Old 06-24-2012
Senior Cruiser
sea_hunter's Avatar
Hmmm, The hose came off?
sea_hunter is offline
post #8 of 10 Old 06-24-2012
KNOT KNOWN
Capt.aaron's Avatar
Rarely is there a hose to no where. When you pump the ball does fuel come out of it? Follow it, where does it go? It may have vibrated off, stranger things Have happened. You can deduce what's going on here.
post #9 of 10 Old 06-24-2012
dnf777's Avatar
That merc doesn't have an overflow line. Rare as it may occur, yours fell off its nipple somewhere. Get a hose clamp at the auto parts store, find where it goes, and secure it with the better clamp. Should be a fitting right inside the cowling, opposite the fuel hook-up. May be hidden deep, but its there. Other end goes to a square plate which is a diaphram pump.
dnf777 is offline
post #10 of 10 Old 06-25-2012 Thread Starter
Thanks everyone, I will have another look.
What is wrong here?? RandyBC Seamanship & Navigation 8 05-03-2010 12:47 AM
What went wrong? Classic30 General Discussion (sailing related) 44 03-25-2008 02:49 AM
What went wrong? vabuckeye Learning to Sail 18 11-25-2007 07:56 AM
Sometimes, when everything goes wrong... CharlieCobra General Discussion (sailing related) 18 08-23-2006 06:08 PM
