Sheared off nylon screw - SailNet Community
post #1 of 11 Old 06-25-2012 Thread Starter
captainrizzo's Avatar
Part of my Furlex 100 maintenance regime requires that I remove a nylon screw on the lower bearing assembly, put grease in, and replace the screw. I do this twice per year. Yesterday, when I was putting the screw back in place, the head sheared off, and the screw is stuck, slightly recessed in the fitting. The good news is that the screw is stuck, so the opening is sealed. The bad news is that the screw is stuck!
The screw is small M6X10 and I donít want to risk damaging the threads by using a drill and EZ Out tool. I am thinking that I can heat a jewelers screwdriver and melt a small slot, let it cool, and then back it out. Has anyone has ever tried this? If so, how much heat, etc.?
I donít want to back the screw out until I have a replacement screw which should be in by Saturday. I will update how the project went upon completion, but meanwhile, I would like to get some feedback on my approach! Thanks in advance!
-Riz
2005 Catalina 350 Grazia
"If you want to build a ship, don't herd people together to collect wood. Just teach them to long for the endless immensity of the sea"
Antoine de Saint
My Blog:
captainrizzo is offline
post #2 of 11 Old 06-25-2012
Geoff54's Avatar
Re: Sheared off nylon screw
What you propose might work but the problem I see is that ,if it doesnít, you will have to drill it and you now have a messed up area to try and center a very small drill bit. I would center punch/drill/extract - if you use a left hand drill bit and drill very slowly, you may not need the extractor, especially in something soft. I would have an M6 metal bolt and tap ready to check and clean up the threads if needed (a rough thread will chew up your nylon screw) and also a thread insert (helecoil/recoil/threadsert), just incase it gets messed up completely. If you need to tap it, after it has started, put grease on the tap to hold the swarf and wipe and replace it frequently. Iím guessing you already know all of this anyway but are looking for a better way Ė I'd just be concerned that it could create a worse problem. Good Luck.
Geoff54 is offline
post #3 of 11 Old 06-25-2012
I remove sheared nylon screws all the time. Get a small flat head, (jewelers) slightly smaller than the screw diameter. Gently tap into the screw body. then gently rotate it out.
I would not use mineral grease on a nylon screw, as it will soften, and weaken the screw over time, as you just found out. Use a teflon, or other lubricant that doesn't contain solvents. What is the material the nylon screw is imbedded in? If it is metal or another hard substance, turning the drill bit by hand will remove the plastic with minimal damage to the threads.
The Sun has Risen on a New Day filled with the Promise of Adventure.
CapnBilll is offline
post #4 of 11 Old 06-25-2012 Thread Starter
Bill, thanks for your idea about gently tapping the jewelers screwdriver and turning a bit by hand. I only use Superlube synthetic grease with teflon for the fuller. I think the housing is metal, not sure what type though.
-Riz
Antoine de Saint
My Blog:
post #5 of 11 Old 06-25-2012
TQA
Bombay Explorer 44
TQA's Avatar
Used to deal with this all the time.
Take a screwdriver slightly smaller than screw diameter. Heat it up to more than boiling but less than red. Push it into the nylon. It will make a slot. Wait for a few seconds and unscrew it.
This almost always worked for me.
TQA is offline
post #6 of 11 Old 06-25-2012
Mermaid Hunter
SVAuspicious's Avatar
Red face Re: Sheared off nylon screw
EZ Out. Replace with metal bolt and TefGel.
SVAuspicious is offline
post #7 of 11 Old 06-25-2012
Wish I never found SN!
SimonV's Avatar
I second this but I heat the flat blade screw driver to a point that it melts the screw, push it in the pull it out making the slot, let cool then unscrew.
EDIT: OH I think I just said what TOA said but different.
Simon
I miss my boat
Brisbane
DELIVERY SKIPPER
Drinking Rum before 10am makes you a Pirate NOT an alcoholic
SimonV is offline
post #8 of 11 Old 06-25-2012 Thread Starter
Success!
I heated up a jewelers screwdriver with a Bic lighter, gave it a couple of taps with a small hammer and voilŗ! I put a M6X10 metalic screw in and will replace with a nylon screw when my order arrives! Thanks all for your suggestions!
-Riz
Antoine de Saint
My Blog:
post #9 of 11 Old 06-26-2012
Mermaid Hunter
Congrats.
post #10 of 11 Old 06-26-2012
rizzo-
fyi, nylon is attacked by petroleum-based lubricants. That and UV over the years might be why it broke. With the metal replacement, loctite or antiseize becomes mandatory, toss a coin for which you prefer but if that bolt is essential, you might want to use loctite and make sure you've got a spare.
hellosailor is offline
Nylon Tie Downs - Dinghy sab30 Gear & Maintenance 11 10-08-2009 12:00 PM
3-Strand Polyester or Nylon trantor12020 Gear & Maintenance 21 01-28-2009 09:30 AM
nylon nuts and bolts grampian23 Gear & Maintenance 2 02-20-2004 04:48 PM
Nylon or Dacron ? Strega Gear & Maintenance 3 08-08-2003 09:03 AM
