Pump Problem - SailNet Community
post #1 of 9 Old 06-26-2012 Thread Starter
RNC725
Pump Problem
Came in yesterday from a short weekend trip, went to pump out the holding tank --- about a 1.5 second normal noise, then it sounded like it "grounded to a stop". Waited a couple of seconds turned it on, still felt like either A -- low battery power or B -- just didnt work.
I suspect, and I'm certainly NO authority here, that it could be a clogged macerator pump -- what are your thoughts and ideas.
Never have had a problem with the pump or this issue ever. Nothing was done differently, nothing went in the head abnormally, in fact I had just pumped her out a couple of weekends ago. It was just me and my wife out for 3 days on this trip.
Never had hooked up, taken apart, cleaned, unclogged anything yet with the macerator or even any hoses related to the head -- I'm a lucky guy indeed methinks. We are on freshwater and I do know that helps.
Any/all help, tips, advice, jokes etc are welcomed as usual.
Bobby Centers
s/v CIRCLE
1967 Cal-30
Augusta, GA
RNC725 is offline
post #2 of 9 Old 06-26-2012
Re: Pump Problem
It's God's way of telling you to go to a pumpout station instead of pumping your crap into the river/lake/whatever you're on.
MarkSF is offline
post #3 of 9 Old 06-26-2012
St Anna's Avatar
Re: Pump Problem
Guess what,
Its a dirty, smelly job.
No-one else will volunteer for it. Welcome to the real world of cruisers, - [poo busters T shirt required]
St Anna is offline
post #4 of 9 Old 06-26-2012
rugosa's Avatar
Re: Pump Problem
Don't leave this job to an apprentice - CALL THE HEAD MECHANIC
rugosa is offline
post #5 of 9 Old 06-26-2012
Re: Pump Problem
Possibly you should eat more bran
Jorries is offline
post #6 of 9 Old 06-26-2012
Seņor Member
PorFin's Avatar
Re: Pump Problem
Yep, the time's come for you to get your hands dirty.
Like every other part of the boat, the macerator ain't gonna live forever.
You need to isolate the fault.
- Disconnect the plumbing (but not the power leads) from the macerator.
- Check your hose runs and seacock/through hull for obstructions.
- Test macerator briefly while disconnected to see if it's still growling.
- If so, remove and disassemble. Assess whether to rebuild or replace.
PorFin is offline
post #7 of 9 Old 06-26-2012
Wish I never found SN!
SimonV's Avatar
Re: Pump Problem
What are you pumping out?. where are you pumping it too, shore facility of lake? Was the tank full, could you have ran the unit dry?
Simon
Ericson 39B.
I love my boat
S/V GOODONYA
Brisbane
present location Gold Coast
DELIVERY SKIPPER
Drinking Rum before 10am makes you a Pirate NOT an alcoholic
SimonV is offline
post #8 of 9 Old 06-26-2012
Tim R.'s Avatar
Re: Pump Problem
Sounds like a clogged vent or a dead Macerator or a really bad clog. Check the vetn first. It is the easiest solution.
Can't wait to go swimming in Lake Thurmond next time I am in Georgia
Tim R.
Our Carina is for sale
1997 Caliber 40LRC
Tim R. is offline
post #9 of 9 Old 06-26-2012 Thread Starter
RNC725
Re: Pump Problem
was attemting to pump out at our dock, we have portable pump out station
was pumpng out probably 1/3 tank full (or less)mainlly liquid, some solid
should no have had anything else in their cept for TP
freshwater, not salt water
never had a probem
again, new to all this, so I guess I'll unhook the fittings to/from Macerator (not electircal)see if I can find a clog, not sure about the vent but will SNIFF aroundtill I find her
actually our water is clean and all are welcome
thanks and please keep these tips coming
Bobby Centers
s/v CIRCLE
1967 Cal-30
Augusta, GA
RNC725 is offline
cw manual bilge pump, bike pump type b40Ibis Gear & Maintenance 2 04-27-2011 08:26 PM
pump out problem bruceyp Gear & Maintenance 8 07-08-2010 02:09 PM
Pump problem or ?? jbondy Gear & Maintenance 4 07-06-2010 01:49 PM
Yanmar 2QM15 raw water pump problem menado Gear & Maintenance 3 07-23-2008 03:20 PM
Problem with pump for manual head voodooacrobat Gear & Maintenance 6 07-06-2006 05:24 PM
