Companionway Hatch - SailNet Community
post #1 of 7 Old 06-25-2012 Thread Starter
Companionway Hatch
Some years ago the companionway hatch on my Newport 28 II was painted, now the paint around the edges, approx 1 inch wide, is pealing off and the wood lamination underneath is falling apart in small thin peaces. Any recommendations on how I can repair this or where I can find a good used companionway hatch?
Donaldpeter is offline
post #2 of 7 Old 06-26-2012
Sailor
Gladrags1's Avatar
Re: Companionway Hatch
Not familiar with the boat but is it possible to remove the hatch and cover with epoxie before reinstalling? Might make a more permanent repair.
Mandolin
Bayfield 36
Sailing out of Rock Creek, Chesapeake Bay
Gladrags1 is offline
post #3 of 7 Old 06-26-2012
JimsCAL's Avatar
Sounds like they are plywood. If they are in really bad shape, make some new ones. If they are basically sound, some epoxy filler and a new coat of paint will get you a few more years.
JimsCAL is offline
post #4 of 7 Old 06-26-2012
Sabreman's Avatar
Companionway Hatch
I'd buy some teak and make a solid wood set of boards. Plywood is a losing proposition unless very well sealed with epoxy at the edges.
Sabre 38 "Victoria"
Sabreman is offline
post #5 of 7 Old 06-26-2012
I'm not sure whether you're referring to the hatch boards, or the surrounding frame. Either way, when wood is in that state it's easiest to start again with new - wood or transparent acrylic or a combination of both.
However if you have the time and inclination, you could strip the paint, apply penetrating epoxy to the loose areas of wood, then a thicker epoxy to build it up, sand fair, then paint or varnish. BTDT, cost me as much in materials as new wood would have cost - but it was winter so I had plenty of spare time
MarkSF is offline
post #6 of 7 Old 06-26-2012
The trick to making plywood last is 2-3 coats of neat (unthickened) epoxy, followed with paint. The goal to to completely encapsulate the wood in epoxy so it never is exposed to the air or moisture. Done right this is a permanent fix.
Personally though I would go to Lowes and buy some clear or smoked lexan, and cut it to size using the old one as a template. It will allow a lot more light downbelow, and is very workable.
Greg
Stumble is offline
post #7 of 7 Old 06-26-2012
Go to the scrapyard and find a piece of 1/8th inch aluminium plate. Cut it out and have the edges bent in a brake press, which should leave you with a four 2 inch welds for them to do. Then you have a permanent , zero maintenance hatch.
Brent Swain is offline
Companionway hatch wmjr Pacific Seacraft 6 04-25-2012 10:35 AM
Companionway hatch for E-27? captainbrad Ericson 5 09-25-2011 10:46 PM
cal 2- 30 companionway hatch klatt Cal 0 06-16-2011 02:12 PM
Companionway Hatch weephee Gear & Maintenance 8 04-25-2010 08:36 PM
Companionway Hatch drh1965 Newport 7 08-15-2008 03:14 PM
